diy sonotube
tecmo04
tecmo04 Posts: 421
so all this talk about diy subs has realy inspired me to try one myself. unfortunatly i know absolutly nothing about this process. all i know is that i wnat to try and build a beast that can change my heart beat and shake my teeth out. so here are a few questions to get me started...
1-id like to build a sonotube so where do io buy the tube?
12" or 15"?
height?
plate amp or seperate?
size and leigth of ports?
cost?
hrs and difficulty of construction?
yada yada yada ...
any help and advise would be GREATLY appreciated.
Post edited by tecmo04 on
  • hoosier21
    hoosier21 Posts: 4,420
    edited June 2005
    Let a little google in your life :D
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • tecmo04
    tecmo04 Posts: 421
    edited June 2005
    im trying to get some expert input, hense asking the pros...
  • hoosier21
    edited June 2005
    Try your local concrete supply company, the local Home Depot and Lowe don't have the big enough tubes (not in my area anyway) Also, sonotube is a brand name, but any of the concrete form tubes will do
    No pro here, but
    12" or 15"?
    Not sure if you asking about the tube size or the subwoofer driver size, but for heart beat changing teeth rattling, I would go 15" driver
    height?
    You gotta pick a driver first
    you choice, plate amp has many features not on a separtae amp, crossover, phase adjustment and such
    cost?
    depends on your driver and amp selction, but it is easy to get a great sub for around 500.00(150 driver, 200 amp, 80 for the tube, 30 or so of wood (MDF) screws and glue, 50 for the finish)
    hard to say how long it will take you to make it, plan on 10-20 hours and it is not hard at all
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2005
    Yeah, what he said.
    Since all the Ascendant drivers are probably gone, I would suggest getting one of the new AV12 or AV15 drivers from (former Stryke Audio). They are monster woofers.
    LINK
  • ohskigod
    ohskigod Posts: 6,505
    edited June 2005
    my .02, go plate amp. ive tried both routes and plate amps always worked better for me. Maybe its what they were designed to do, i dont know. but i get much better performance in my DIY subs from a plate amp.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • michael_w
    michael_w Posts: 2,813
    edited June 2005
    download a program called unibox ... its actually an excel worlcsheet with macros. You will need the specs of the driver first.
    I would probably go plate amp because it already has features lilce crossover and phase.
  • Ron-P
    Ron-P Posts: 8,520
    edited July 2005
    My DIY Sonosub is a 24"x36" tube with 2-3"x17" flared port kits and a bit of batting wrapped around the inside of the sonotube. It has a single 15" Tempest driver and is powered by a 250w plate amp from Partexpress.
    If...
    Ron loves a film = don't even rent.
  • michael_w
    edited July 2005
    or try a program called winIsd... both have their advantages over each other but if you dont have ms excel use winIsd.
