speakers only work when pushed
Systems
Systems Posts: 14,872
edited June 2005 in Car Audio & Electronics
my cerwin vega v-max 12 inch single voice coil, only seem to work when i push the cone in. Then they stop working after a lil while. The bass still hits the same when working but they just sop and play whenever. I took out the subs, and both register about 4 ohms a piece. I don't think it s the voice coil, but im not shure.I have a ma audio hk800d amp, and a crossover......PLEASE HELP ME!!!!!!!!!!!!!!
Testing
Testing
Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited June 2005
    that's just strange... so you're saying that they need you to push them, then they'll play for a while, then they'll randomly stop, but when you push them again, they'll play?
    if that is indeed the case, it sounds like it's sticking somewhere inside (like spilling pop on a keyboard). try this - if you play a strong bass beat really loud, will they begin to play on their own, or do they still need a push?
    also, just because, make sure the tinsel leads are solid (the wires that go from the terminals on the sub into the center, make sure they're still attached well).
  • [Deleted User]
    [Deleted User] Posts: 763
    edited June 2005
    Sounds like a loose wire. Either the tinsel leads or a broken voice coil.
  • Jstas
    Jstas Posts: 14,996
    edited June 2005
    Could be that the spider has separated from the motor structure.
    Expert Moron Extraordinaire
  • exalted512
    exalted512 Posts: 10,734
    edited June 2005
    My guess is the tinsel leads
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2005
    This sounds like a good excuse to go buy something else!!
    Im always on the lookout for a reason to buy more toys! :D
  • neomagus00
    edited June 2005
    everyone's here throwin out repair suggestions, and mac steps in and goes "repair? bah! get new stuff! who needs cash, anyways?"
    well, maybe not quite like that, but it was still mildly amusing :p.
  • swerve
    swerve Posts: 1,862
    edited June 2005
    buy my 2 12" MM2124's...
    -adam
    cats.vans.bag...
  • MacLeod
    edited June 2005
    No, thats pretty much it. Ya cant take it with ya!!! :p
    I have several mottos. One of which is "you can always upgrade and should do so as often as possible"!
  • swerve
    swerve Posts: 1,862
    edited June 2005
    what's the other ones? That's pretty amusing... i highly doubt you have several.
    You can't upgrade much more than pyle subs and pyramid amps these days
    cats.vans.bag...
