Sound Deadening project
spwuinmk67
Yesterday I started putting the Second Skin spectrum in my truck. I did a nice thick coat on my doors last night, then I spent a lot of today figuring out how everything came apart inside so I could take the carpet, headliner, and all the panels out. I wound up stripping two of the seat belt bolts due to them being rusted, so they are still stuck there. God damn torex bolts. Any suggestions on a way to get those out would be appreciated. I took a bunch of pics, so as soon as I find the cable to hook it up, I'll post them. I put 2 more thick coats on the doors, a very, very thick coat on the floors and back wall, and a thinner coat on the roof. My oringinal intent was to spray the spectrum on, but when I was putting the quick connect end to hook it up to the air hose, I cracked the spray gun. I'm gonna contact Ant and see if there is anything I can do about that. I wound up painting it on though. Went on easy, and dried rather quick. Not a bad odor to it, did smell a little bit when I went to work this morning, but not too bad overall.
1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
Post edited by spwuinmk67 on
alright, I found the cable. I don't know how to add more then one pic at a time, so there will be a few. This is the driver side door panel masked off, before I put the spectrum on.1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
And with the spectrum....1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
passanger side door with spectrum, didn't bother with out1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
Inside the truck with everything out of it, except the two seat belt bolts which wouldnt come out. It was easy enough to get around them though, the one in the middle, i looped around the steering wheel and taped it off, the other was a pain. I couldnt take the other panel off without getting that bolt out, so I took the whole panel and seat belt, and stretched it outside of the truck, and let it sit under neath. I taped off what was still inside though, so It didn't get ruined.1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
another inside1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
beautiful
As far as the seat belts go, first option is vice grips, second option is drill a hole through the middle a little ways, then get a screwdriver and hammer it into the hole and try to get it out that way. if that fails, you might just have to drill the whole thing out but be careful not to mess up the threads or youre really f***ed
the pile of wires and misc parts on my dash....1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
outside of the truck, for those who haven't seen it1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
a pile of parts that came out of the truck1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
front part of the truck masked off1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
back windows masked...1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
front floor1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
back floor and wall1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
top back wall and roof1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
This is what it looks like when dry. This was after the first coat on the doors.1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
That looks like a breeze to paint on compared to V3. Man V3 you cannot make even it's pathetic.cats.vans.bag...
v3 also goes on thicker and has better dampening properties. theres trade offs for everything
yea but it looks horrible... my trunk lid was the best... but atleast i can say i'm rattle free and it only took me 2 days.... soon that won't be the case though...Originally posted by exalted512
-Codycats.vans.bag... -
its covered by carpet and plastic-quit complaining
all over MJs face
Damn SP, now thats the way you do an install.
There is absolutely no way Id have the initiative, discipline or patience to do something like that.
Thats the way to go tho, good for you!polkaudio sound quality competitor since 2005
Yes, it goes on thicker, but it has the same damping properties as V2 when they're applied at equal thicknesses.Originally posted by exalted512
-Codyhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
ant told me different, he also mentioned something about less likely to rust out the metalOriginally posted by AustinKP
wow. that's a pretty big difference.....Originally posted by exalted512
-Cody
-adamcats.vans.bag...
