Sound Deadening project
spwuinmk67
spwuinmk67 Posts: 797
edited June 2005 in Car Audio & Electronics
Yesterday I started putting the Second Skin spectrum in my truck. I did a nice thick coat on my doors last night, then I spent a lot of today figuring out how everything came apart inside so I could take the carpet, headliner, and all the panels out. I wound up stripping two of the seat belt bolts due to them being rusted, so they are still stuck there. God damn torex bolts. Any suggestions on a way to get those out would be appreciated. I took a bunch of pics, so as soon as I find the cable to hook it up, I'll post them. I put 2 more thick coats on the doors, a very, very thick coat on the floors and back wall, and a thinner coat on the roof. My oringinal intent was to spray the spectrum on, but when I was putting the quick connect end to hook it up to the air hose, I cracked the spray gun. I'm gonna contact Ant and see if there is anything I can do about that. I wound up painting it on though. Went on easy, and dried rather quick. Not a bad odor to it, did smell a little bit when I went to work this morning, but not too bad overall.
1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com
Post edited by spwuinmk67 on
  • spwuinmk67
    edited June 2005
    alright, I found the cable. I don't know how to add more then one pic at a time, so there will be a few. This is the driver side door panel masked off, before I put the spectrum on.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    And with the spectrum....
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    passanger side door with spectrum, didn't bother with out
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    Inside the truck with everything out of it, except the two seat belt bolts which wouldnt come out. It was easy enough to get around them though, the one in the middle, i looped around the steering wheel and taped it off, the other was a pain. I couldnt take the other panel off without getting that bolt out, so I took the whole panel and seat belt, and stretched it outside of the truck, and let it sit under neath. I taped off what was still inside though, so It didn't get ruined.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    another inside
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • exalted512
    exalted512 Posts: 10,735
    edited June 2005
    beautiful
    As far as the seat belts go, first option is vice grips, second option is drill a hole through the middle a little ways, then get a screwdriver and hammer it into the hole and try to get it out that way. if that fails, you might just have to drill the whole thing out but be careful not to mess up the threads or youre really f***ed
    -Cody
  • spwuinmk67
    edited June 2005
    the pile of wires and misc parts on my dash....
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    outside of the truck, for those who haven't seen it
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    a pile of parts that came out of the truck
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    front part of the truck masked off
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    back windows masked...
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    front floor
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    back floor and wall
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    top back wall and roof
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spwuinmk67
    edited June 2005
    This is what it looks like when dry. This was after the first coat on the doors.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • swerve
    swerve Posts: 1,862
    edited June 2005
    That looks like a breeze to paint on compared to V3. Man V3 you cannot make even it's pathetic.
    cats.vans.bag...
  • exalted512
    edited June 2005
    v3 also goes on thicker and has better dampening properties. theres trade offs for everything
    -Cody
  • swerve
    swerve Posts: 1,862
    edited June 2005
    -Cody
    yea but it looks horrible... my trunk lid was the best... but atleast i can say i'm rattle free and it only took me 2 days.... soon that won't be the case though...
    cats.vans.bag...
  • exalted512
    edited June 2005
    its covered by carpet and plastic-quit complaining
    -Cody
  • swerve
    swerve Posts: 1,862
    edited June 2005
    plastic? please tell me where?
    cats.vans.bag...
  • exalted512
    edited June 2005
    all over MJs face
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2005
    Damn SP, now thats the way you do an install.
    There is absolutely no way Id have the initiative, discipline or patience to do something like that.
    Thats the way to go tho, good for you!
  • AustinKP
    AustinKP Posts: 861
    edited June 2005
    -Cody
    Yes, it goes on thicker, but it has the same damping properties as V2 when they're applied at equal thicknesses.
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • exalted512
    edited June 2005
    ant told me different, he also mentioned something about less likely to rust out the metal
    -Cody
  • swerve
    swerve Posts: 1,862
    edited June 2005
    -Cody
    wow. that's a pretty big difference.....
    -adam
    cats.vans.bag...
