Speakers for Jolida Hybrid
I bought a Jolida 1501RC Hybrid. My CD is a mmf cd - 25. My speakers are RTi8's. I'm looking for an opinion on what floorstanding speaker will give me a better "musical" sound. Possibly more midrange and lower base frequency. I think the Polks are missing the bottom end of the spectrum. I am 2 channel and dont use a sub, I primarily listen to music.
Patrick
Patrick
Jolida JD1501RC -Telefunken tubes
Jolida JD9 Phono Stage
Rega P2- Dynavector 10x4 Mk.II Cartridge
Music Hall mmf cd-25
Canton Ergo 900 DC
Polk PSW404
Kimber "Timbre" IC's
Tributaries "SP4BW" - bi-wired
Canton Ergo 900 DC
Polk PSW404
Post edited by PRC on
There are literally hundreds of options, but we need to know what your budget is to narrow the field a little.
Offhand, you can always go up the Polk chain with the Lsi15.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
You should also consider upgrading the opamps in that Music Hall CD-25 to opa627's
Let me know if you're interested....very cheap! 2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Thanks. I would say my used budget is around a $1000.00 for both speakers. I will look at the LSi15's. I appreciate the info.
I do not know what this means:
"upgrading the opamps in that Music Hall CD-25 to opa627's"
PatrickJolida JD1501RC -Telefunken tubes
Canton Ergo 900 DC
Polk PSW404
Tributaries "SP4BW" - bi-wired -
Sorry.........
I have a second question. The LSi15's say "Nominal Impedance 4 ohms". Do i have to use 4 ohms.........waht is a ohmJolida JD1501RC -Telefunken tubes
Canton Ergo 900 DC
Polk PSW404
Originally posted by PRC
Sorry.........
waht is a ohm
No....you've got it slightly wrong. A waht is a measure of power whereas an ohm is a measure of resistance....get it?
