Speakers for Jolida Hybrid
PRC
PRC Posts: 58
edited June 2005 in Speakers
I bought a Jolida 1501RC Hybrid. My CD is a mmf cd - 25. My speakers are RTi8's. I'm looking for an opinion on what floorstanding speaker will give me a better "musical" sound. Possibly more midrange and lower base frequency. I think the Polks are missing the bottom end of the spectrum. I am 2 channel and don’t use a sub, I primarily listen to music.
Patrick
Jolida JD1501RC -Telefunken tubes
Jolida JD9 Phono Stage
Rega P2- Dynavector 10x4 Mk.II Cartridge
Music Hall mmf cd-25
Canton Ergo 900 DC
Polk PSW404
Kimber "Timbre" IC's
Tributaries "SP4BW" - bi-wired
Post edited by PRC on
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    There are literally hundreds of options, but we need to know what your budget is to narrow the field a little.
    Offhand, you can always go up the Polk chain with the Lsi15.
    "God grooves with tubes."
  • dragon1952
    dragon1952 Posts: 4,923
    edited June 2005
    You should also consider upgrading the opamps in that Music Hall CD-25 to opa627's ;) Let me know if you're interested....very cheap!
  • PRC
    PRC Posts: 58
    edited June 2005
    Thanks. I would say my used budget is around a $1000.00 for both speakers. I will look at the LSi15's. I appreciate the info.
    I do not know what this means:
    "upgrading the opamps in that Music Hall CD-25 to opa627's"
    Patrick
    Canton Ergo 900 DC
    Polk PSW404
  • PRC
    PRC Posts: 58
    edited June 2005
    Sorry.........
    I have a second question. The LSi15's say "Nominal Impedance 4 ohms". Do i have to use 4 ohms.........waht is a ohm
    Canton Ergo 900 DC
    Polk PSW404
  • dragon1952
    edited June 2005
    Originally posted by PRC
    Sorry.........
    waht is a ohm
    :confused:
    No....you've got it slightly wrong. A waht is a measure of power whereas an ohm is a measure of resistance....get it? :(
