DVD-A and SACD copies?
brettw22
brettw22 Posts: 7,623
edited April 2024 in Clubhouse Archives
Can you make a copy of either format using a disc to disc box so you have a backup option in case the originial gets scratched to hell?
I'm wondering if a standard HT type cd copier would work with those formats......
  • nadams
    nadams Posts: 5,877
    edited June 2005
    you _should_ be able to create a copy of a DVD-a disk with a DVD burner in a computer. Disk to disk would require two DVD drives. Not sure if computer DVD drives read DVD-A, though... never had one to try.
    SACD, I have no clue.
    Ludicrous gibs!
  • brettw22
    edited June 2005
    Why would it have to be a dvd burner? They're just single layer audio discs with no video on them, aren't they?
  • nadams
    nadams Posts: 5,877
    edited June 2005
    I'm not sure. I guessed that the "DVD" part of their name implied that they were written to a DVD, and the "-A" part of their name meant that they were audio only.
    Correct me if I'm wrong...
    Now, the SACDs, I figure are CDs, but encoded some special way. I'm sure a Google search would show some more information, but I'll leave that up to you.
    Ludicrous gibs!
  • TroyD
    TroyD Posts: 13,124
    edited June 2005
    So basically, you really have no friggin' idea.
    :D
    BDT
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2005
    Gold Jerry GOLD!!!
  • amulford
    amulford Posts: 5,020
    edited June 2005
    Now why would you want to copy them. Dammit, how are they gonna get that new Ferrari with you **** cheating them out of royalties???
  • brettw22
    edited June 2005
    If I have them to copy, then I thought you'd figure out that I had bought them......yutz. :p
    F1nut Posts: 51,747
    edited June 2005
    You can't copy either format.
  • danger boy
    danger boy Posts: 15,722
    edited June 2005
    I doubt your computer's drive would decode the DVD-a or SACD layer on a disc. that's why they sell players to play them.. and you have to use the 6 analog RCA's.
    PolkFest 2012, who's going>?
    billbillw Posts: 7,532
    edited June 2005
    SACD and DVD-A are both basically DVD format disks that hold about 4.7GB
    DVD-A can be copied if you have the right software. Most DVD computer drives will recognize the disk and you can copy/decrypt, and reburn the files. A stand alone copier will not do the trick. You can also play the DVD-A on computers with good multi channel soundcards. This is one of the selling points for the newer Soundblaster Audigy cards.
    SACD is not recognized by computer drives, unless they are a hybrid disk that has a redbook layer. In that case, the computer will see the redbook layer and you can copy that, but you will just end up with a CD.
