speakers only work when pushed
Systems
my cerwin vega v-max 12 inch single voice coil, only seem to work when i push the cone in. Then they stop working after a lil while. The bass still hits the same when working but they just sop and play whenever. I took out the subs, and both register about 4 ohms a piece. I don't think it s the voice coil, but im not shure.I have a ma audio hk800d amp, and a crossover......PLEASE HELP ME!!!!!!!!!!!!!!
Testing
Testing
Testing
Testing
Testing
that's just strange... so you're saying that they need you to push them, then they'll play for a while, then they'll randomly stop, but when you push them again, they'll play?
if that is indeed the case, it sounds like it's sticking somewhere inside (like spilling pop on a keyboard). try this - if you play a strong bass beat really loud, will they begin to play on their own, or do they still need a push?
also, just because, make sure the tinsel leads are solid (the wires that go from the terminals on the sub into the center, make sure they're still attached well).It's not good, very fundamentally simply not good. - geolemon
Sounds like a loose wire. Either the tinsel leads or a broken voice coil.
Could be that the spider has separated from the motor structure.Expert Moron Extraordinaire
My guess is the tinsel leads
This sounds like a good excuse to go buy something else!!
Im always on the lookout for a reason to buy more toys!
everyone's here throwin out repair suggestions, and mac steps in and goes "repair? bah! get new stuff! who needs cash, anyways?"
well, maybe not quite like that, but it was still mildly amusing
. It's not good, very fundamentally simply not good. - geolemon
No, thats pretty much it. Ya cant take it with ya!!!
I have several mottos. One of which is "you can always upgrade and should do so as often as possible"!polkaudio sound quality competitor since 2005
what's the other ones? That's pretty amusing... i highly doubt you have several.Originally posted by MacLeod
You can't upgrade much more than pyle subs and pyramid amps these dayscats.vans.bag...
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
