Installing Shielding Magnets
kdrives
kdrives Posts: 13
edited June 2005 in Troubleshooting
HI:
ANybody have directions to install shidleing magnets on SDA 2B's Received my package but no directions
I believe I super-glue them on, but is it the "attraction" way or the "resistance" way ??
Does that make sense
Dave
Post edited by kdrives on
    F1nut Posts: 52,002
    edited June 2005
    5 minute epoxy works better and you want them installed the "resistance" way. Don't forget to do the tweeter.
  • kdrives
    kdrives Posts: 13
    edited June 2005
    ok, I'll get some...
    And yes, I have Mag's for all three in each
    It made sense that the glue was rather un-necessary doing it the "attraction", as they were pretty much impossible to separate doing it that way...
    Thanks!!!
  • kdrives
    kdrives Posts: 13
    edited June 2005
    All magnets installed and appear to be working fine...
    Thanks for those who helped
    A BIG thanks to Kim for the call
    Dave
