Question about the Jolida JD-100
dragon1952
dragon1952 Posts: 4,921
edited June 2005 in Electronics
The Jolida I just bought seems to occassionally have a problem recognizing that there is a disc inserted. This seems to happen when I either leave it in standby or leave it powered on overnight with a CD in it. I'll hit play and the CD will spin forwards and backwards for a few seconds and then display 'No Disc". This happens even if I eject the CD and re-insert it. Powering the player off and on seems to clear the problem. Does anyone else's player do this?
Post edited by dragon1952 on
  • TroyD
    TroyD Posts: 13,124
    edited June 2005
    mine doesn't, no.
    BDT
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    I used to own a Cambridge Audio 500SE CD player that exhibited the traits you're describing. I sent it back for a full refund. I never knew what was causing it.
    "God grooves with tubes."
    F1nut Posts: 52,002
    edited June 2005
    No problem with mine. Send it back for repair.
  • pjdami
    pjdami Posts: 1,894
    edited June 2005
    Same here with no problems like that. It even plays burned copies of my disks.
    I hate to ask the very obvious but you have tried different cds right? If so, something is definitely up with it unfortunately.
    Paul
  • dragon1952
    edited June 2005
    No man.....it's like I'll play a CD one evening, leave the CDP powered on or in standby for several hours or overnight with the CD still in the transport, come back and press play...it spins for a few seconds and then displays 'No Disc'. I'll power the unit completely off and then back on and everything's fine. It's not a big deal if I was definitely going to keep it, but if I decide to sell it I have to divulge this and it hurts the resale value. The guy I bought it from is like "Oh yeah, that's a well known glitch with the Jolida and everyone knows about it" . That's a bunch of **** because I've Googled the **** out of it and come up with nothing.
    F1nut Posts: 52,002
    edited June 2005
    That is a pile of BS he's feeding you. Make him take it back or pay for the repair.
  • pjdami
    pjdami Posts: 1,894
    edited June 2005
    I agree. I don't think the seller was totally honest with you.
    I briefly tried scouring some of the AA threads here for the problem and didn't find anything like that either.
    http://db.audioasylum.com/cgi/search.mpl?searchtext=jolida+jd100+problem&b=OR&topic=&topics_only=N&author=&date1=&date2=&slowmessage=&sort=score&sortOrder=DESC&forum=digital
  • Early B.
    edited June 2005
    I agree. If he didn't disclose that information to you beforehand, he's gotta make it right.
  • mulveling
    mulveling Posts: 505
    edited June 2005
    I had a JD100a for a year and it never did that. That guys is feeding you BS, since I never heard of that glitch either.
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • Early B.
    edited June 2005
    Dragon -- what did you decide to do?
  • dragon1952
    edited June 2005
    Well it does mention this potential problem in the back of the manual. It says that due to the all-metal casing that they are prone to static electricity which evidently can cause this very same problem. Just says to turn it off and back on which is what I've been doing. Also, I've been leaving the cover off to do some tube rolling. I don't know if this is exascerbating the problem or not.. It's really not a big deal though. I was just wondering if this had happened to anyone else.
    Appreciate all the advice and support though ;)
    F1nut Posts: 52,002
    edited June 2005
    Rob,
    Ya gotta put the cover back on man. The laser isn't going to be able to read much with other light sources shining in on it.
  • dragon1952
    edited June 2005
    Rob,
    :o Aww, do I have to? :( It seems to be playing OK and it sure is easier to roll tubes! :(
    BTW, I gotta tell you....that was one mother of a cover to remove!
