Hardwiring a PS2 in the car...
Ace_TX
Ace_TX Posts: 2
edited June 2005 in Car Audio & Electronics
Can this be hardwired into a car or must you use it with an inverter?
Post edited by Ace_TX on
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2005
    Your car has a 12 volt DC power supply. The PS2 requires a 120 volt AC power supply. In other words, youd have to have an inverter.
    Check out truck stops. Over the road truckers use em to hook up their tv's and microwaves and whatever. Usually can find good deals on em there.
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited June 2005
    Or get a PSP car charger, I believe we carry them at Radioshack. You can use either the plug, or chop the end off and hard wire it.
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • bknauss
    bknauss Posts: 1,441
    edited June 2005
    PS2 converts 120VAC to 12VDC... so you can hook up the battery straight to the PS2. Use the magical site called google to find instructions.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • MacLeod
    edited June 2005
    No ****? Id never heard of that.
    Shows what I know. :(
  • spwuinmk67
    edited June 2005
    I'm going to forget i made my earlier reply, due to the fact that i, for some reason, thought it said psp, not ps2. I'm going to walk away in shame now...lol
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2005
    It has to be the newer slim model with the outboard transformer. The older models have the transformer inside and would require wiring past the internal transformer to use on 12VDC. Or use an inverter as I do.
  • neomagus00
    neomagus00 Posts: 3,899
    edited June 2005
    if you get an inverter and mount it, say, in the side of the center console, you then have up to three plugs that are seamlessly integrated into the car, one of which can be used to power a ps2...
    i plan on mounting mine to the left of the passenger's knees.
  • Dennis Gardner
    edited June 2005
    Inverters are great for powering 120 VAC stuff, just know that some have pretty loud fans to deal with.
  • bknauss
    edited June 2005
    Why go spend all that money on an inverter when you can splice some wires, solder a little bit, and have the PS2 hooked up for probably a couple dollars worth of stuff?
    That's my 2 cents.
    Brian Knauss
  • Thom
    Thom Posts: 723
    edited June 2005
    Josh hard- wired the one in our Civic...
  • [Deleted User]
    [Deleted User] Posts: 763
    edited June 2005
    Yeah, it wasn't hard. Just get to the main PC board and test (with a VOM) until you find the leads for the 12V after the transformer. We don't have switch in the Civic. It comes on whenever the car's on and you just hit the reset button on the front.
