Hardwiring a PS2 in the car...
Ace_TX
Can this be hardwired into a car or must you use it with an inverter?
Post edited by Ace_TX on
Your car has a 12 volt DC power supply. The PS2 requires a 120 volt AC power supply. In other words, youd have to have an inverter.
Check out truck stops. Over the road truckers use em to hook up their tv's and microwaves and whatever. Usually can find good deals on em there.polkaudio sound quality competitor since 2005
Or get a PSP car charger, I believe we carry them at Radioshack. You can use either the plug, or chop the end off and hard wire it.1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
PS2 converts 120VAC to 12VDC... so you can hook up the battery straight to the PS2. Use the magical site called google to find instructions.Brian Knauss
ex-Electrical Engineer for Polk -
No ****? Id never heard of that.
Shows what I know.polkaudio sound quality competitor since 2005
I'm going to forget i made my earlier reply, due to the fact that i, for some reason, thought it said psp, not ps2. I'm going to walk away in shame now...lol1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
It has to be the newer slim model with the outboard transformer. The older models have the transformer inside and would require wiring past the internal transformer to use on 12VDC. Or use an inverter as I do.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
if you get an inverter and mount it, say, in the side of the center console, you then have up to three plugs that are seamlessly integrated into the car, one of which can be used to power a ps2...
i plan on mounting mine to the left of the passenger's knees.It's not good, very fundamentally simply not good. - geolemon
Inverters are great for powering 120 VAC stuff, just know that some have pretty loud fans to deal with.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Why go spend all that money on an inverter when you can splice some wires, solder a little bit, and have the PS2 hooked up for probably a couple dollars worth of stuff?
That's my 2 cents.Brian Knauss
Josh hard- wired the one in our Civic...
Yeah, it wasn't hard. Just get to the main PC board and test (with a VOM) until you find the leads for the 12V after the transformer. We don't have switch in the Civic. It comes on whenever the car's on and you just hit the reset button on the front.
