Circuite City/good service.
MSALLA
MSALLA Posts: 1,602
edited June 2005 in Electronics
I have to give them credit. My new DLP TV started acting-up. I was getting bright green lines on the contours of objects on the screen.It's almost 3 months old and when I called they said just bring it up and we'll give you a new one.So yesterday they swapped it out for a new set, no questions asked.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Post edited by MSALLA on
  • izafar
    izafar Posts: 820
    edited June 2005
    I had mixed experience so far. My RPTV had green horizontal band that I found when it was 2 weeks old, called them and they brought a new one to my home and pickup up the old one, that was a happy story.
    Now one year later the TVs convergence has gone bad, and the repair ticket is open for last three weeks. Apparently they are waiting for a part. When I ask about how long I have to wait, the CC rep says that I have a wait for a couple of months for the part, if they couldn’t get the parts by then they will replace the unit.
    The way I read it is if the TV is under Manufacturer warranty then they will issue a replacement easily, but if Manufacturer warranty has ended and it is covered by CC warranty, then they will try their best not to replace it.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2005
    What model is it? Have you tried to manually converge it? I check mine every 3 months. Most RPTV's I've seen will very slowly "drift" out of convergence.
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2005
    Over the last 15 years Ive been shopping at CC Ive always had excellent customer service.
    Cant say the same for Best Buy. Eff them!
  • 2+2
    2+2 Posts: 546
    edited June 2005
    IIRC Circuit city works off commissions....I dont think Best buy does....
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • izafar
    izafar Posts: 820
    edited June 2005
    It is Samsung HCN4226W. Its convergance amplifier has gone bad and isnt responding to auto and manual convergence. According the tech, who saw it, this is a common issue with this model and is usually fixed by replacing the convergence board.
    -izafar
  • goingganzo
    goingganzo Posts: 2,793
    edited June 2005
    i have a samsung and it has alot of hours and no problems it is a seccond gen with the mustang chipset. it is a 42 in
  • fireshoes
    fireshoes Posts: 3,167
    edited June 2005
    Neither do anymore.
  • SuperDave
    SuperDave Posts: 168
    edited June 2005
    Best Buy replaced a DVD player I purchased over two months later with no extended warranty or even a receipt. I had purchased it with a credit card so they could verify my purchase date through their system. The customer rep said I would have to go to the manufacturer normally but for customer satisfaction I could go get a replacement off the shelf. Good move on their part.
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • dipiazza
    dipiazza Posts: 363
    edited June 2005
    I just took my sony 300 CD changer to Circuit city for extended service i purchased almost 3 years ago. theyre attempting to repair it. i hope they cant so i can get a new one, but they were good on the extended service.
    by the way, what could cause the CDP to randomly start skipping even on brand new CDs? sometimes it works perfectly the next time i use it, it may skip. random.
    thanks
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
  • izafar
    izafar Posts: 820
    edited June 2005
    thanks
    most probably either lens need cleaning or alignment is going out on the laser pickup.
    -izafar
  • goingganzo
    edited June 2005
    usaly alignment if it was cleaning then it would be constant
