Circuite City/good service.
MSALLA
I have to give them credit. My new DLP TV started acting-up. I was getting bright green lines on the contours of objects on the screen.It's almost 3 months old and when I called they said just bring it up and we'll give you a new one.So yesterday they swapped it out for a new set, no questions asked.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
Post edited by MSALLA on
I had mixed experience so far. My RPTV had green horizontal band that I found when it was 2 weeks old, called them and they brought a new one to my home and pickup up the old one, that was a happy story.
Now one year later the TVs convergence has gone bad, and the repair ticket is open for last three weeks. Apparently they are waiting for a part. When I ask about how long I have to wait, the CC rep says that I have a wait for a couple of months for the part, if they couldnt get the parts by then they will replace the unit.
The way I read it is if the TV is under Manufacturer warranty then they will issue a replacement easily, but if Manufacturer warranty has ended and it is covered by CC warranty, then they will try their best not to replace it.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
What model is it? Have you tried to manually converge it? I check mine every 3 months. Most RPTV's I've seen will very slowly "drift" out of convergence. -
Over the last 15 years Ive been shopping at CC Ive always had excellent customer service.
Cant say the same for Best Buy. Eff them!polkaudio sound quality competitor since 2005
IIRC Circuit city works off commissions....I dont think Best buy does....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
It is Samsung HCN4226W. Its convergance amplifier has gone bad and isnt responding to auto and manual convergence. According the tech, who saw it, this is a common issue with this model and is usually fixed by replacing the convergence board.-izafar
i have a samsung and it has alot of hours and no problems it is a seccond gen with the mustang chipset. it is a 42 in
Neither do anymore. -
Best Buy replaced a DVD player I purchased over two months later with no extended warranty or even a receipt. I had purchased it with a credit card so they could verify my purchase date through their system. The customer rep said I would have to go to the manufacturer normally but for customer satisfaction I could go get a replacement off the shelf. Good move on their part.SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
I just took my sony 300 CD changer to Circuit city for extended service i purchased almost 3 years ago. theyre attempting to repair it. i hope they cant so i can get a new one, but they were good on the extended service.
by the way, what could cause the CDP to randomly start skipping even on brand new CDs? sometimes it works perfectly the next time i use it, it may skip. random.
thanksTerps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
thanks
most probably either lens need cleaning or alignment is going out on the laser pickup.-izafar
usaly alignment if it was cleaning then it would be constant
