FS: SDA2b DFW LOCAL ONLY $125
RuSsMaN
A buddy of mine is selling a pair of 'handyman special' 2b's.
SL2000's, woofs and PR are all working great. PR's show SLIGHT bubbling in couple places - not noticeable unless you are right up on them. One of the SL2000's is missing a mounting screw, and shows some minor surface rust on the inner screws.
One binding post on the rear of the right speaker was replaced (generic), and same speaker has a pretty good sized gash on the rear corner. These are woodgrain VINYL wrapped.
Grilles are complete, with logos, one could use a touch of glue on the rear in a couple spots tore-attached the fabric. Blade blade SDA2b's on risers, comes with original blade/blade cable.
Not the prettiest pair, but perfect working order - $125 and little cleanup and you've got a nice set of speaks.
If interested EMAIL me, or POST HERE, and I'll put you in touch with him.
Cheers,
Russ
Cheers,
Russ
Post edited by RuSsMaN on
What a steal! I would feel guilty about buying these since I already have a pair and don't need them. Mine are pin/blade 2b's. Does that mean these 2a's? What a deal for a newbie or anybody wanting to try the sda's.
They are single vertical mounted tweeter, but with risers. I think this is one of those 'transition' models that Polk has become known for.
Don't feel bad, take em. Matter of fact, we are having a bottlehead meet this weekend in Richardson, TX, and several SA/Houston guys are coming up.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
No. It means that there were two versions of the 2B. A blade/blade version and a pin/blade revised version. The pin/blade version was introduced only seven months after the blade/blade version.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Thanks but I know someone from Dallas will want these or even OKC or Tulsa. I'm very happy with mine.
I'm a bit confussed. I have a pair of SDA 2? that I bought new, they have a single vertical mounted tweeter and a blade/blade cable. Are these 2a's or 2b's? I thought because they were blade/blade that made them 2a's. So are my speakers first version 2b's? Thanks2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
1984---SDA 2, two tweeters, two MW6501 drivers per cabinet, blade/blade SDA cable.
1986---SDA 2A, one tweeter, two MW6510 drivers per cabinet, blade/blade SDA cable.
March 1987---SDA 2B, one tweeter, one MW6503 stereo driver, and one MW6511 SDA driver per cabinet, blade/blade SDA cable.
October 1987---SDA 2B-revision 1, one tweeter, one MW6503 stereo driver, and one MW6511 SDA driver per cabinet, pin/blade SDA cable.
1989---SDA 2B-revision 2, one tweeter, one MW6503 stereo driver, and one MW6511 SDA driver per cabinet, pin/blade SDA cable. Polyswitch is changed.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Thanks Darque, I'll have to pull the drivers to see exactly what I have.2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Then, you have the SDA 2B.1.5s
Mine have one crossover board that's the rev. 1 board (marked SDA 2B), the other the rev. 2 (marked SDA 2B/CRS+). Drivers and tweeters were dated DEC '88 in one cabinet and JAN '89 in the other. And, yes, they're an original pair. I'm the second owner. -
