RTi4 or RTi6 for surrounds?
Hey guys Im doing a 5.1 setup with RTi8 or 10 for my fronts. I really cant put speakers behind me so they will need to be on the side so I have decided to go with a front firing speaker. Which would you guys recommend for the rears> the 4's or the 6's?
Testing
Testing
Testing
Testing
Testing
have you tried auditioning them yourself?
Imo i don't see the need for a huge surround speaker unless you have a great deal of amplification and a huge room to boot. The rti-4 should do fine. I have a 20x15 room and this is what i use:
Front- rti4
Center- csi3
Sides- Fx300i dipole
Rears- Fx300i Bipole
Pre/Pro- H/K 235
Adcom 5300 2ch. amp
Adcom 7300 5ch. amp
btw- welcome to the forum.
Hey thanks man.
I cant find a place to try them out. : ( Im buying blind.
I heard the entire RTi series almost 3 years ago before I was really into audio. All I remember was they sunded great. lolTesting
Testing
Testing -
Have you looked at the FXi line. I have the FXi5's and love them. They are mounted on each side of my listening position.
I have the RTi6's in 7.1 HT. They sound very good. A lot clearer than the RTi38's which are on the side.Michael
NORTH of 60° -
Get the largest speakers you can afford that will work for your setup-- in your case it's the RTi6. At one time I had RTi28's then switched to RTi38's and there was a big difference. The Fxi5's will work well, too.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
zachwhite- let's start over- lol.
how big is your room?
what are you driving your speakers with?
also, if you want side surrounds JDSMOKE is right. you might benefit from the f/x's more so than the rti's- especially for movie playback; and the f/x's are timbre-matched to RTI's as well.
EDIT: you can listen to RTI's at Tweeter Stores. Is there one near to where you live? -
No tweeter stores.:(
So If the speakers are gonna be beside me then I want the FXi5 and if they are gonna be behind me I want the RTi6 or 4?
My room is very small. It is 11 by 14
I will be using a HK AVR635Testing
Testing
Testing -
I have a set each of the RT35i and the RT25i, which were basically earlier versions of the current RTi4 and RTi6.
I actually like the RT25i better as a main 2 channel speaker, but I like the RT35i better as a surround, so I vote for the RTi6 for surround duty. It's midwoofer is the same size as those in your mains and center.
I also like a regular speaker better as a surround instead of a dipolar. Dipolars might have been good with plain old vanilla Dolby Pro Logic, but I think regular speakers are better with todays discreet 5, 6, or 7.1 formats.
Good luck! -
I don't think matching the mid drivers is as important as the tweets.
I use the 4 as my rears and I like them very much. I was using jbl's the 4s blow them away in every aspect. I did not increase the volume but everything is clear and more detailed. -
with a room that size rti4's or f/xi 3's will be plenty.
I would still pick the fx's for surround duty over the monopoles. Dipoles are great for movies and bipoles are great for multi-channel music and with the F/x's you can switch between the two. jmo.
Fronts- RTI-4
Center-CSI-3
Sides- F/X300i (Dipole)
Rears- F/X300i (Bipole)
Sub- Velo Cht10
Pre/Pro- Harman Kardon 235
Amp- Adcom 5300 2ch, 7300 5ch. -
LSi/FX - end of conversation!!!!!!!!!!!!!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
