RTi4 or RTi6 for surrounds?
Systems
Systems Posts: 14,873
edited June 2005 in Speakers
Hey guys Im doing a 5.1 setup with RTi8 or 10 for my fronts. I really cant put speakers behind me so they will need to be on the side so I have decided to go with a front firing speaker. Which would you guys recommend for the rears> the 4's or the 6's?
Testing
Testing
Testing
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2005
    have you tried auditioning them yourself?
    Imo i don't see the need for a huge surround speaker unless you have a great deal of amplification and a huge room to boot. The rti-4 should do fine. I have a 20x15 room and this is what i use:
    Front- rti4
    Center- csi3
    Sides- Fx300i dipole
    Rears- Fx300i Bipole
    Pre/Pro- H/K 235
    Adcom 5300 2ch. amp
    Adcom 7300 5ch. amp
    btw- welcome to the forum. =)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Systems
    edited June 2005
    Hey thanks man.
    I cant find a place to try them out. : ( Im buying blind.
    I heard the entire RTi series almost 3 years ago before I was really into audio. All I remember was they sunded great. lol
    Testing
    Testing
    Testing
  • JDSMOKE
    JDSMOKE Posts: 31
    edited June 2005
    Have you looked at the FXi line. I have the FXi5's and love them. They are mounted on each side of my listening position.
  • janmike
    janmike Posts: 6,146
    edited June 2005
    I have the RTi6's in 7.1 HT. They sound very good. A lot clearer than the RTi38's which are on the side.
    Michael ;)
    NORTH of 60°
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    Get the largest speakers you can afford that will work for your setup-- in your case it's the RTi6. At one time I had RTi28's then switched to RTi38's and there was a big difference. The Fxi5's will work well, too.
    "God grooves with tubes."
  • aaharvel
    edited June 2005
    zachwhite- let's start over- lol.
    how big is your room?
    what are you driving your speakers with?
    also, if you want side surrounds JDSMOKE is right. you might benefit from the f/x's more so than the rti's- especially for movie playback; and the f/x's are timbre-matched to RTI's as well.
    EDIT: you can listen to RTI's at Tweeter Stores. Is there one near to where you live?
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Systems
    edited June 2005
    No tweeter stores.:(
    So If the speakers are gonna be beside me then I want the FXi5 and if they are gonna be behind me I want the RTi6 or 4?
    My room is very small. It is 11 by 14
    I will be using a HK AVR635
    Testing
    Testing
    Testing
  • marker
    marker Posts: 1,084
    edited June 2005
    I have a set each of the RT35i and the RT25i, which were basically earlier versions of the current RTi4 and RTi6.
    I actually like the RT25i better as a main 2 channel speaker, but I like the RT35i better as a surround, so I vote for the RTi6 for surround duty. It's midwoofer is the same size as those in your mains and center.
    I also like a regular speaker better as a surround instead of a dipolar. Dipolars might have been good with plain old vanilla Dolby Pro Logic, but I think regular speakers are better with todays discreet 5, 6, or 7.1 formats.
    Good luck!
  • Willow
    Willow Posts: 11,228
    edited June 2005
    I don't think matching the mid drivers is as important as the tweets.
    I use the 4 as my rears and I like them very much. I was using jbl's the 4s blow them away in every aspect. I did not increase the volume but everything is clear and more detailed.
  • aaharvel
    edited June 2005
    with a room that size rti4's or f/xi 3's will be plenty.
    I would still pick the fx's for surround duty over the monopoles. Dipoles are great for movies and bipoles are great for multi-channel music and with the F/x's you can switch between the two. jmo.
    Fronts- RTI-4
    Center-CSI-3
    Sides- F/X300i (Dipole)
    Rears- F/X300i (Bipole)
    Sub- Velo Cht10
    Pre/Pro- Harman Kardon 235
    Amp- Adcom 5300 2ch, 7300 5ch.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • pearsall001
    pearsall001 Posts: 5,257
    edited June 2005
    LSi/FX - end of conversation!!!!!!!!!!!!!
