keb Mo
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited June 2005 in Music & Movies
I've seen his name mentioned quite a bit, but haven't heard him yet.
If I'm gonna go out and buy one of his albums to see if I dig his stuff, which one should I get first?
Post edited by AsSiMiLaTeD on
  • hoosier21
    hoosier21 Posts: 4,420
    edited June 2005
    I have three of his, all are very good.
    The Door
    Just like you
    Slow down
    I would try "The door" first, it is worth the price of the CD for just the song "Beginning"
    I am sure you know this, but go to Amazon, you can sample tracks of each CD there.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Roy Munson
    Roy Munson Posts: 886
    edited June 2005
    You might also try:
    Keb' Mo'- Keb' Mo'
    This has some great acoustic guitar and some good slide work!
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
  • Tide
    Tide Posts: 154
    edited June 2005
    All good recommendations above, but I like most of Keb's stuff, your mileage may vary. If you've got HT, the Sessions at West 54th is a great DVD.
    Go here and listen to the clips for yourself:
    http://www.kebmo.com/
    Click on music
    SDA 2s; HSU STF-2; Yamaha RX-V1
    SDA-CRSs; Polk PSW-303; Rotel RB-960BX; Rotel RSP-960AX;
    LSi 7s; Infinity PS8; Rotel RB-980BX; Rotel RSP-980
    Mirage Nanosat 5.1; Yamaha RX-V2300
    Monitor 5s, 5 jrs, & 4s
  • uncyogi
    uncyogi Posts: 24
    edited June 2005
    Not long ago, Keb Mo was just a vaguely familiar name to me. Now, less than one year (and five CD's) later, he's one of my favorites. I recomend his music highly!! But tastes vary so like others have said, check out some clips on line before putting down any hard earned money.
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    You can also go to amazon.com and listen to 30 second or 1 minute clips of each song on most CDs, in general. That way, you can determine which ones you like. It's also a great place to buy used CDs.
    "God grooves with tubes."
    F1nut Posts: 51,916
    edited June 2005
    Keb Mo is cool, period.
