keb Mo
AsSiMiLaTeD
I've seen his name mentioned quite a bit, but haven't heard him yet.
If I'm gonna go out and buy one of his albums to see if I dig his stuff, which one should I get first?
Post edited by AsSiMiLaTeD on
I have three of his, all are very good.
The Door
Just like you
Slow down
I would try "The door" first, it is worth the price of the CD for just the song "Beginning"
I am sure you know this, but go to Amazon, you can sample tracks of each CD there.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
You might also try:
Keb' Mo'- Keb' Mo'
This has some great acoustic guitar and some good slide work!2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
All good recommendations above, but I like most of Keb's stuff, your mileage may vary. If you've got HT, the Sessions at West 54th is a great DVD.
Go here and listen to the clips for yourself:
http://www.kebmo.com/
Click on musicSDA 2s; HSU STF-2; Yamaha RX-V1
SDA-CRSs; Polk PSW-303; Rotel RB-960BX; Rotel RSP-960AX;
LSi 7s; Infinity PS8; Rotel RB-980BX; Rotel RSP-980
Mirage Nanosat 5.1; Yamaha RX-V2300
Monitor 5s, 5 jrs, & 4s -
Not long ago, Keb Mo was just a vaguely familiar name to me. Now, less than one year (and five CD's) later, he's one of my favorites. I recomend his music highly!! But tastes vary so like others have said, check out some clips on line before putting down any hard earned money.
You can also go to amazon.com and listen to 30 second or 1 minute clips of each song on most CDs, in general. That way, you can determine which ones you like. It's also a great place to buy used CDs.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Keb Mo is cool, period.Political Correctness'.........defined
