RTi 12's wall distance
brockmouse1
brockmouse1 Posts: 4
Hallo,
newbi to all of this....
just set up my new RTi12's front and HT.
any hints on how far they have to be from the wall.....my HT room is huge...42 x 38. seating area about 20' from main front speakers, and the center.
At the moment there are 2' from the back wall.
any hints would be great.
thanks.
brockmouse1
Post edited by brockmouse1 on
  • steveinaz
    steveinaz Posts: 19,546
    edited June 2005
    Generally, the farther they are from the back wall, the better your soundstaging/imaging will be; the closer they are, the more bass will be enhanced.
    Experiment and enjoy, you've got a huge room to play with.
  • BrentMcGhee
    BrentMcGhee Posts: 548
    edited June 2005
    i think with the 2feet of breathing room that they already have i dont think moving them out any further will yield any better or worse results.
  • Toxis
    Toxis Posts: 5,116
    edited June 2005
    I'd say 1.5-2 ft. should be good but that's something you should really play around with. Also, toe them in if you listen to a lot of music. Play around... that's the beauty of audio. The slightest thing will greatly affect the sound. Have fun!!
