RTi 12's wall distance
brockmouse1
brockmouse1 Posts: 4
Hallo,
newbi to all of this....
just set up my new RTi12's front and HT.
any hints on how far they have to be from the wall.....my HT room is huge...42 x 38. seating area about 20' from main front speakers, and the center.
At the moment there are 2' from the back wall.
any hints would be great.
thanks.
brockmouse1
  • steveinaz
    steveinaz Posts: 19,547
    edited June 2005
    Generally, the farther they are from the back wall, the better your soundstaging/imaging will be; the closer they are, the more bass will be enhanced.
    Experiment and enjoy, you've got a huge room to play with.
  • BrentMcGhee
    BrentMcGhee Posts: 548
    edited June 2005
    i think with the 2feet of breathing room that they already have i dont think moving them out any further will yield any better or worse results.
  • Toxis
    Toxis Posts: 5,116
    edited June 2005
    I'd say 1.5-2 ft. should be good but that's something you should really play around with. Also, toe them in if you listen to a lot of music. Play around... that's the beauty of audio. The slightest thing will greatly affect the sound. Have fun!!
