MM2124 Power Question
Systems
can a MM2124 handle 460w RMS? If so, i have a 2-channel kenwood amp that puts out 460w x1 when bridged, so i could get the single 4 ohm sub, and that would run good, correct??
Testing
Testing
Testing
Testing
Testing
The sub is rated for 400 watts. That means thats the most it is designed to handle.
If youre careful with the gain and volume you wont really have a problem. You dont start your car up at 75 mph do ya? Its the same with an amp. Its not always putting out 460 watts.
Here is a good gain setting tutorial to go by.polkaudio sound quality competitor since 2005
would the 15" be better able to handle 460w rms? i think its still rated at 400 rms too.Testing
Testing
Testing -
why not just turn the gain down a little?? ive had nothing but bad experiences with putting even a little more than a polk subs RMS
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
