MM2124 Power Question
Systems
Systems Posts: 14,872
edited May 2005 in Car Subwoofer Talk
can a MM2124 handle 460w RMS? If so, i have a 2-channel kenwood amp that puts out 460w x1 when bridged, so i could get the single 4 ohm sub, and that would run good, correct??
Testing
Testing
Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited May 2005
    The sub is rated for 400 watts. That means thats the most it is designed to handle.
    If youre careful with the gain and volume you wont really have a problem. You dont start your car up at 75 mph do ya? Its the same with an amp. Its not always putting out 460 watts.
    Here is a good gain setting tutorial to go by.
  • Systems
    edited May 2005
    would the 15" be better able to handle 460w rms? i think its still rated at 400 rms too.
    Testing
    Testing
    Testing
  • exalted512
    exalted512 Posts: 10,734
    edited May 2005
    why not just turn the gain down a little?? ive had nothing but bad experiences with putting even a little more than a polk subs RMS
    -Cody
