SDA-SRS 2.3 TLs
Philpfeif
Post edited by Philpfeif on
I sit about equal distance with mine. i haven't moved them since I set them up. Congrats on your score. Let's see some pics. Are you going to put the new tweeters in them?
JT -
The equal distance rule is quite proper and works extremely well. It's not a Polk derived guide rule to say nothing of being SDA or SRS specific. It is a standard audio guide for stereo listening.
Congrats on the "new" 2.3s. Enjoy
If you didn't get the manual, contact Ken at Polk and he'll mail one to you. Ideally, a equal laterial triangle of 6 to 8 feet is best and do not toe-in the speakers.Political Correctness'.........defined
President of Club Polk -
I guess I have just gotten used to being farther away from my speakers. I now have them about 7.5 feet apart edge to edge and I am sitting about 12 feet back and they sound great. Thanks for the suggestion about the manual. The original owner has the manual but he couldn't find it. Is there a big improvement in the new replacement tweeters. I plan to rebuild the crossovers but if there is a good reason to replace the tweeters I will do that too.
Phil -
Phil,
Not that reworking the crossovers isn't a worthy project but changing the tweeters is a quicker, easier, satisfying upgrade to do. You'll only be wanting to do it anyways if you do the crossovers first.I now have them about 7.5 feet apart edge to edge
IF by this you mean 7.5' inside edge to inside edge, your speakers are actually "closer" to being 9.25' apart. This is measuring the speakers at the tweeters or the middle of the speaker. Its the left tweeter to right tweeter and tweeters to ear measurments your interested in. -
That makes more sense. The diagram on the back of the speakers shows the measurement from inside edge to inside edge. I wll order the tweeters on Tuesday. Thanks for all the advice.
I concur, get the new tweeters first and get the manual. You can then play around with full knowledge on set up and what sounds best to you.Political Correctness'.........defined
Yeah, all the diagrams will show the measurement between the speakers taken at the inside edges. This practice never made total sense to me but I guess it at least gives a general guide line to follow. I've always made a practice of using the tweeters as my point of measure.
Enjoy the 2.3s. -
Thanks guys for all the help.
