Early's DIY Sub
Probably around 24 or 25hz.Originally posted by Early B.
Thanks.
Can someone calculate the tuning frequency of this sub for me? I thought it was tuned for 20 Hz, but I'm not sure. The sub is 6 c.f. and has two 4" diameter ports 17" long. What other stats are needed for the calculation?
Does that 6 cu ft include all the bracing and port volume taken out of the total volume? If it doesn't, you're probably tuned a little higher.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Very nice job on the sub !
1 question for you, how did you find in relation to buying the equivilant pre-made what was the price diff ? -
What formula or software did you use to calculate this?Probably around 24 or 25hz.
The 6 c.f. is the box itself. Don't know how much space the inner braces and ports take up.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
This DIY cost me about $400 to make. A comparably priced sub would be the Hsu STF-2 which I've owned. You simply can't compare the power and performance between a 10" and 15" driver, plus a higher quality amp and bigger box. I'd say you'd have to spend at least three times the money for the same level of performance.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I've thought about this myself.
Does anyone know what a 9 cubic foot, 15" driver, 272 watt subwoofer, tuned to 18 Hz would cost from SVS? (obviously I mean what would the closest thing SVS sells cost?)Bob Mayo, on the keyboards. Bob Mayo. -
I used unibox. It's an excel spreadsheet that someone created. I'm using it to design my sub for the Atlas 15.Originally posted by Early B.
The 6 c.f. is the box itself. Don't know how much space the inner braces and ports take up.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
This is just a guess but I'll bet it performs around the PB2 subs performance. The 15" driver probaby displaces as much air as the two 12" ISD drivers, but that's just a guess. The two Plus drivers might out do a single atlas 15, but that's also just a guess. Maybe Doc will chime in...Originally posted by gmorris
Does anyone know what a 9 cubic foot, 15" driver, 272 watt subwoofer, tuned to 18 Hz would cost from SVS? (obviously I mean what would the closest thing SVS sells cost?)Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
OK, but I'm just wondering why your 24-25 Hz figures differ from the fellas on the Ascendant Audio forum at www.soundillusions.net. They say a 6 c.f. box would yield 20-21 Hz. They are referring to Chad's own box design which is the model I used for mine. Are you taking into consideration both ports?
I downloaded unibox last week. Couldn't figure out how to use it. It ain't for the novice (not this novice, at least).
I like to keep it simple. Can I test this myself in the real world with a Rat Shack SPL meter and some low bass tones?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Yes, both ports are taken into consideration. I'd have to see his design to figure it out myself but I don't know why they would get different numbers. The software isn't an exact science, I'm sure.Originally posted by Early B.
You could test it yourself. You'd probably have to take the sub outside to get the best results, but I think you need to measure the freq response from about 1 meter away. once the response starts diving off a cliff then you've hit the tune point. Be careful when you get below the tune point because that is when the woofer can go beyond it's excursion limits.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Thanks, tryrrthg. I might try that. I'll need some bass tones. Anybody know of a website where I can download them?
BTW -- here's the link for the sub's design:
http://www.frontiernet.net/~trtinkerer/overview.html
I changed it from a square to a rectangle.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I'll check out the design some time this weekend.Originally posted by Early B.
here are the tones I use. Download all the individual tones.
http://www.snapbug.ws/sinewaves/Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
OK, got some final pics here...
On this one, can you locate the sub?
Very nice, EB!
Have you re-checked the hangar/mount on that elephant head?!? I'd hate to see a headline like "Atlanta couple found impaled in home theatre - apparent case of sonic suicide."
That's funny. But since I've heard that some people's subs on this forum have knock things off the wall, I am a bit concerned about some of the art in the room. Also, the fireplace screen rattles a lot, so I'll probably have to remove it whenever we watch a movie.Have you re-checked the hangar/mount on that elephant head?!? I'd hate to see a headline like "Atlanta couple found impaled in home theatre - apparent case of sonic suicide."
Kinda annoying, too.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Beautiful room, to say the least! Congrats on a successful project.
Looks good Early. It's great to see more people interested in, and participating in DIY audio.Graham
Thanks Sid and tryrrthg for the bass tones. I'll try them out this weekend and post my results.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Thanks for the tips early. I have all the tools I need (dad's a cabinet builder) and he cuts all his wood in his "shop"... 5' by 8' room :rolleyes: I have some closed cell foam tape stuff that I'll use to seal the port openings. I belive the port openings should be about 6-1/4" or something like that. My ports didn't come with instructions. Did you use some kind of pvc cleaner and cement to put them together? Does the atlas come with a sealant gasket thing or do I need to get some more closed cell foam to put around the cutout?
Run a reverse sine sweep and keep your fingers on the woofer and a hand over the ports. When the woofer excursion gets minimal and a lot of air is rushing from the ports, that is the tuning frequency Fb.
If you want to get more technical, take a mic and place it very close to the woofer cone and run a sweep. There will be an obviously dip in the response at the tuning frequency."What we do in life echoes in eternity"
SVS -
Yeah, PVC cement. Extremely strong smell. Works in seconds, so move fast.
The Atlas does not come with a gasket. Not sure if using cell foam around the cutout is necessary. I used it because my cutout was slightly larger than it needed to be.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Didn't like the black finish on my sub, so I went to Advance Auto Parts and bought two cans of black/gray Duplicolor splatter paint designed for truck bed liners. Here's the first coat:HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Pic of the top:HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I like that better than the black. Adds a touch on uniqueness. Nice job.Michael
NORTH of 60° -
Looks good. Kind of rock like
I thought about doin that too but I think I'm going to try bed liner first. I thought the plain gloss black looked a little too fingerprintable/smudgy at certain angles but this looks great. -
Nice! I like that look. I might have to run that one by the wife.
I'm still designing my sub but my Atlas 15 is due to arrive tomorrow! Can't wait!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Yeah, thanks. It's looking real good right now. I added a second coat last night and checked on it this morning. Now I can set drinking glasses and other stuff on the sub without worrying about messing up the finish.
Gonna leave it in the garage for a couple of days to remove as much of the paint odor as possible. I'll admit, I got a bit overzealous and spray painted the box without covering the amp and ports (I left the back of the unit black, though). Some of the splatter paint splattered on the binding posts, so I'll have to clean that up. Next time I'll be more careful.
BTW -- the truck bed liner is great stuff. About $5/can. Very easy to apply and looks awesome.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
That truck bed liner smell will last for weeks on end...
After it is dry, spray some type of febreeze, etc on it and then wipe it down immediately.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
