cs350ls...any good ?
I have a chance to get a cs350ls for a good price..
Is the 245 better ?
I`m thinking of using 2 ea 245 centers , but using the 350
would mean only one center on the tv..
Is the 245 better ?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
Post edited by beardog03 on
I have the 350 and love it. I consider only the 400, CSi40, and in some instances the 1000p to be the few Polk centers to better the 350.
I think it looks better than all of those on top of a TV also, since it has a long low profile instead of the boxy look that the bigger woofs require.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
i have the 350ls and love it been using it for about 7 years good solid center has been through 4 receivers and now has an adcom amp on itSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
Could you define...."good price"?Originally posted by beardog03
Is the 245 better ?
would mean only one center on the tv.. -
trubluluc
asking $125..
I was going to use my two 245 as right and left ch comming out of the amp...even though the signal will be going from AVR to y-connect, to r/l channels in mono ( I think)Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Definately worth the asking price. It will resell here if you don't like it. I already have one but would take it for that.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
If I understand you that is what I am doing with mine.
I actually run 3 speakers in the front and the 2 on the sides are running off a seprate amp. splitting the center pre-out signal.
Works great for me.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
....yes, a very good price.Originally posted by beardog03
trubluluc
asking $125..
