SDA tweeter replacement question
bdaley6509
bdaley6509 Posts: 1,167
edited May 2005 in Speakers
Has anyone had a chance to compare the RD0194 and 198 tweeters? Is there a big difference in sound. I bought the 94's for my 2.3tl's not realizing there was a 98. Any info would be appreciated. I'm not 100% I got the model numbers right, but hopefully I'm close. Thx.
Post edited by bdaley6509 on
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2005
    The RD0194 (SL2000) and RD0198 (SL3000) are electrically and sonically dissimilar, although, the RD0194 is closer in sound to the RD0198 than the SL2000 is to the SL3000.
    You risk damaging the RD0194 by using it in a speaker designed for the SL3000 and vice versa.
    Forum member madmax experimented with this kind of switch in a prior post.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2005
    And he was never quite the same....
