Amp Help!
anumericrae1
anumericrae1 Posts: 6
edited May 2005 in Car Subwoofer Talk
i just purchased 2 12s polk audio db series. the question is....whats a good amp to power these badboys up to its fullest potential?
Post edited by anumericrae1 on
  • neomagus00
    neomagus00 Posts: 3,899
    edited May 2005
    the hifonics bx1205d comes to mind, but it really depends upon your budget, and whether you have the SVC or DVC models.
  • denim
    denim Posts: 79
    edited May 2005
  • neomagus00
    edited May 2005
    Originally posted by denim
    what is the VC set up and how much can you spend?
    which is, of course, exactly what i asked... :rolleyes:
  • exalted512
    exalted512 Posts: 10,734
    edited May 2005
    yea but he says it straight out, you say it as far away of the point as you can get
    -Cody
  • neomagus00
    edited May 2005
    Originally posted by neomagus00
    ...it really depends upon your budget, and whether you have the SVC or DVC models.
    um... in addition to offering a reasonable suggestion, that's about as clear as can be.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited May 2005
    Speaker has 2 connections, one + and one - then it = Single Voice Coil (SVC)
    Speaker has 4 connections, two +'s and two -'s it = Dual Voice Coils (DVC)
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • 1996blackmax
    edited May 2005
    If you have SVC's then you can wire them up as a 2ohm load.
    I would recommend a Kicker KX600.1. I had one and it put out 740 watts RMS. This would be a nice match for your subs.
    http://www.crutchfield.com/S-MXzCevCg7wp/cgi-bin/ProdView.asp?g=130&I=2064KX6001
    If you have DVC's this MB Quart looks like a great deal. You can wire the amp for a 2ohm stereo load. You will get over 800 watts RMS (400 X 2), but you can play with the gains a little to get a little less.
    http://www.crutchfield.com/S-MXzCevCg7wp/cgi-bin/ProdView.asp?g=110&I=049RAA2400
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
