Amp Help!
anumericrae1
i just purchased 2 12s polk audio db series. the question is....whats a good amp to power these badboys up to its fullest potential?
Post edited by anumericrae1 on
the hifonics bx1205d comes to mind, but it really depends upon your budget, and whether you have the SVC or DVC models.It's not good, very fundamentally simply not good. - geolemon
what is the VC set up and how much can you spend?
which is, of course, exactly what i asked... :rolleyes:Originally posted by denim
what is the VC set up and how much can you spend?It's not good, very fundamentally simply not good. - geolemon
yea but he says it straight out, you say it as far away of the point as you can get
um... in addition to offering a reasonable suggestion, that's about as clear as can be.Originally posted by neomagus00
...it really depends upon your budget, and whether you have the SVC or DVC models.It's not good, very fundamentally simply not good. - geolemon
Speaker has 2 connections, one + and one - then it = Single Voice Coil (SVC)
Speaker has 4 connections, two +'s and two -'s it = Dual Voice Coils (DVC)Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
If you have SVC's then you can wire them up as a 2ohm load.
I would recommend a Kicker KX600.1. I had one and it put out 740 watts RMS. This would be a nice match for your subs.
http://www.crutchfield.com/S-MXzCevCg7wp/cgi-bin/ProdView.asp?g=130&I=2064KX6001
If you have DVC's this MB Quart looks like a great deal. You can wire the amp for a 2ohm stereo load. You will get over 800 watts RMS (400 X 2), but you can play with the gains a little to get a little less.
http://www.crutchfield.com/S-MXzCevCg7wp/cgi-bin/ProdView.asp?g=110&I=049RAA2400Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
