Need Monitor 10A peerless tweeter replacement
fredv
fredv Posts: 923
edited April 2008 in Vintage Speakers
Hi,
I have a pair of Monitor 10A's that came with the peerless tweeters - have a dimple and very ugly :-)
One of them went south last week - the high is almost all gone.
I still can ear something if I put my ear right in front of the tweeter.
I asked Polk support, but the reply was that Polk could only sell me a SL2000 as
replacement - not even a SL1000.
I surfed the bay for a replacement but
no avail. Clearly, I will have to put in 2
SL2000's; otherwise, the speaker will have
different sound because of different tweeters. Did someone replace this year
of vintage M10 with SL2000? If so, what is your opinion?
Thanks,
-fredv-
-fredv-
Post edited by fredv on
  • danger boy
    danger boy Posts: 15,722
    edited April 2005
    they do show up on Ebay now and then.. keep lookin'.
    also. someone in here might have a spare or two you can buy from them. If you see some on ebay.. buy them.. i think they are becoming a bit scarce now.
    good luck.
    PolkFest 2012, who's going>?
  • fredv
    fredv Posts: 923
    edited April 2005
    good luck.
    Yup yup yup, I am still looking at ebay at this hour. These beast is really hard to find. In fact, I am even considering to
    buy another Monitor 10 for spare parts,
    but most of them had SL2000 or SL2500
    tweeters ... I am just wondering whether
    my tweeter can be repaired or not ...
    Thanks for the reply,
    -fredv-
    -fredv-
  • fredv
    fredv Posts: 923
    edited April 2005
    good luck.
    -fredv-
    -fredv-
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2005
    Just a dry spell. More Peerless will show. Be patient...
    More later,
    Tour...
    Vox Copuli
    mhardy6647 Posts: 35,190
    edited April 2005
    1) Peerless made these tweeters until quite recently. They were in PartsExpress's catalog until just a couple of years ago. There were/are plenty in circulation. Also, lots of other speakers (including some off-brands) used them. Cizek, e.g., though hardly an off-brand, IMO, comes to mind. You might even find a cheap pair of speakers on eBAY with the silk Peerless domes in 'em for less than a pair of raw tweeters would cost you.
    2) Are you absolutely SURE the low output from the tweeter is a driver problem? Were I you, I'd at least swap the good and bad tweeter so you can be certain it's not, e.g., a bad crossover cap.
  • fredv
    fredv Posts: 923
    edited April 2005
    Response to #2 first, I did swap the 2 tweeters and confirmed one is no good, sad. I even bought a used sl2000 from ebay, it just doesn't sound even close the peerless ..... I am going to take the
    peerless apart to see I can find any obvious problem :-)
    A little off topic, I saw a lot of discussion about replacing SL2000 (silver dome) with RE-1904-1 (not sure this is the correct model, silk dome) in the SDA model. Are you referring to this silk dome? If so, I am wondering this will have similar effect to my 10A which (1) doesn't use sl2000, (2) has a different crossover. Just curious, do you know the peerless model number of this tweeter? If so, can you let me know so that I can look it from all possible sources :-)
    Thanks to everyone, this is a great resource for Polk Audio.
    -fredv-
    -fredv-
  • danger boy
    edited April 2005
    won't other polk monitor speakers that used the Peerless tweeter work too? like i know some 7's and 5's used the same peerless. it should just drop right in i think.
    edited April 2005
    The original Peerless model for that tweeter was K010 DT, IIRC. This was NOT the model number PE had for 'em... I do have some old PE catalogs at home and I can check the model number (if I manage to remember to do so).
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2005
    When it comes to Peerless replacement within the Polk line, they are all the same.
    Peerless, the manufacturer, made a tweeter that was useable, but the later versions changed frame sizes, so it wasn't a drop-in anymore.
  • fredv
    fredv Posts: 923
    edited April 2005
    Yup, I am indeed watching ebay everyday for a 7 or a 5 that has the Peerless. As a matter of facts, I am also watching the SDA's as an alternative :D Unfortuantely, it either most of the sellers of these only offer local pickup (I live in San Francisco area) or too expensive to ship... I won't give up, I am determined to retain at least a pair of good old Polk at home:mad:
    Cheers,
    -fredv-
    -fredv-
  • danger boy
    edited April 2005
    don't give up fredv. they are worth holding on to. do you use your Monitor 10's every day? so you'd really like to have a new tweeeter. or are they only used ocassionally?
    al
  • fredv
    fredv Posts: 923
    edited April 2005
    al
    I have the 10A's in my bedroom, and I listen to them more than my wife :D I bought it used a few months ago from local. Boy, that was the best $125 I spent in my life. Cosmetically, it is so so, but sonically, it has been superb until lately :(
    I am watching 2 things from ebay:
    1. the replacement tweeter or any 5's / 7's that has peerless.
    2. A nice SDA posted for sale in my area. I don't really care which series. Supposedly, they are all good, right? And no, they won't be in my bedroom, they will be in the family ;)
    Cheers,
    -fredv-
    -fredv-
  • danger boy
    edited April 2005
    so you're looking for a pair of SDA's? me too.. haven't found any close to me yet.
  • fredv
    fredv Posts: 923
    edited April 2005
    There were 2 SDA's from San Diego in last 3 weeks. There were so close, yet not reachable...... Good that you don't live close by, you know what I mean :p
    -fredv-
    -fredv-
  • danger boy
    edited April 2005
    i'll drive to SD if i have to. don't want to. but a man's gotta do. what a mans gotta do. yeah. uh huh, right. .....
    i'll keep looking around here.
  • fredv
    fredv Posts: 923
    edited April 2005
  • danger boy
    edited April 2005
    Originally posted by fredv
    Hey,
    Have you seen SDA like this? I didn't ...
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=71571&item=5770911175&rd=1
    -fredv-
    I did see those. a bit overpriced if you ask me. that seller.. usually asks to much for his stuff. not that it's in poor quality. but some times he stuff doesn't sell. he rarely relists it again.
    but i am keeping my eye on those. not the SDA's i've been looking for. I'd rather have floorstanding big **** SDA's instead. but at this point. i'll almost settle for any SDA's. ;)
  • dorokusai
    edited April 2005
    Hey,
    -fredv-
    SDA CRS
  • Tour2ma
    edited April 2005
    OK, first you **** about no SDA's close by. Now it's that they're overpriced...
    Move to civilization and maybe the deals will come.... :D
    More later,
    Tour...
    Vox Copuli
  • danger boy
    edited April 2005
    well. you have to match the a pair of SDA's to it's right owner. i'd hate to buy that pair that doesn't fit my personality. know what i mean? :rolleyes:
  • Tour2ma
    edited April 2005
    LOL...
    FYI, same seller has a mint pair of Bose 901 Continentals... not that I'm saying those would be a better match... :D
    More later,
    Tour...
    Vox Copuli
  • jagster
    jagster Posts: 13
    edited April 2008
    Hey guys, two years ago I picked up my SDA 1b's in a system. This poor devil was under pressure from his wife in their new house, and she did not want that 'old stuff' in her new living room. A complete Kenwood system out of the 80's and the SDA's. Everything worked, and I jumped on the whole thing for a hundred bucks. Turned around and sold all the latter-day kenwood stuff on ebay. Then stashed the SDA's for over two years, and finally hooked them up yesterday. Damn me! Better than my Klipsch Heresey's, Pioneer HPM 100's, and yep, even my Dahlquist DQM 7's. Not too far away from my big Marantz HD880's, but they are much more open and sweeter. It is the old one of falling face-first in a pill of dog do-do, and coming up smelling like roses. Really regret taking so long to get these things hooked up. Oh, I sold Polks in my stores back in the early 80's, had two 'snob shops' and we played with all of it.
  • geppy1
    geppy1 Posts: 3,076
    edited April 2008
    Hi, Back to the peerless question. To the gentleman looking for them. I have several. Of more interest is that there are two DIFFERENT Peerless that Polk used. I never could understand the different numbers on back of the tweeters and why two orignal black tweeters pairs sound different. I checked and checked and now know why.
    The early black peerless with 75441880 was made in Denmark (or is it Holland). They are more defined and more aggresive sounding to me. Very misical but not as smooth as the latter version These were used very early around 1980 and before
    The later one 55141081 was made FOR Peerless here in the USA. This one is very smooth and sound somwhat laid back. It was used from around 1980 to 1984 give or take. This is the one I think most people think of when they think Peerless.
  • dorokusai
    edited April 2008
    As mentioned previously, the Peerless tweeter was never exclusive to Polk and is present in a handful of other manufacturers designs.
  • dcmeigs
    dcmeigs Posts: 708
    edited April 2008
    danger boy wrote: »
    There is a pair in The Dalles on ebay.
    The world is full of answers, some are right and some are wrong. - Neil Young
