Anybody familar with Audiosource?
marker
If so, how are they?
I noticed some Audiosource amps on ubid.com that were 400 watts a piece when bridged.
Getting two 400 watt monoblocks for about $400 shipped wouldn't be a bad deal for some of these people in here to drive their power hungry RTi12 set ups.
Post edited by marker on
I've owned a few. I think many of them, if not all, use toroidal power tansformers. Not bad amps at all although I would suggest buying used so if you decide you don't like them you can get your money back. If you get a great Ubid price that might not be too bad. Ebay usually has quite a few of them and they're pretty easy to sell. They are budget amps however, but they should certainly beat most receivers I would think.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I have been meaning to ask, is there anything inherently advantageous or superior to a toroidal power supply over a conventional one (what ever that may be)?System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
Good question, and I don't know what the alternatives are, either. I guess I just thought it either had a toroidal power supply, a larger toroidal power supply, or had one of those new chip amps. Speaking just of SS amplification.
I'm looking forward to an answer, too.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I know conventional power supplies have a rectangular shape rather than the hamburger shape and many manufacturers use toroidal in their higher line products (rotel 1056 vs 1067 for example). Maybe they produce less noise.....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
The lesser Rotel receiver (1056) has an ei core transformer instead of a torodial one.
Here's a few links:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5768259250&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
http://www.tortech.com.au/article.html
http://www.tabtronics.com/toroids.htm
http://www.tbs-electronics.nl/transformers/toradv.html
If you do a google search you'll find more than you ever wanted to know.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
They have less noise.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
A non-tord. power supply...
(that big black thing)
Another one would be the one in your Yammer receiver.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Waaaaait a minute......are you sure my Yammy doesn't have a toroidal transformer...?.......phooey....
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Cool...thanks for the info gents...those Audio Source then have pretty good power supplies considering their price...System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
Interesting...I'm gonna hafta check out those links sometime when I get some more time...
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Well, ubid has them back up again and here they are:
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10367451
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10367396
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10367380
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10367452
I'm very seriously considering getting a pair of those Amp3 to run in 400 watt bridged mode for driving my pair of RTi12.
Even counting shipping charges, a pair of 400 watt monoblocks for less than $500 total wouldn't be half bad at all! -
The AMP 1's, which I owned, are 200W bridged and they're only $79. You'd think 200W would be plenty for anything but a sub maybe.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
The RTi12 IS a sub!
Nice thing about the Amp Two is the signal sensing auto turn on.
