jumpers
Willow
Willow Posts: 11,231
Is is best to use jumpers of the same make as your speaker cable?
The reason I ask is that I run kimber 4pr to my mains
I have :
left-over kimber
left over monster 16awg
left over 12awg HD cable
Kimber is hard to work with I have made 1 set but don't like the looks..all un-even.
I have a pair that I made of the HD looks nice finished in black shrink.
Or should I use the left-over M cable?
Post edited by Willow on
    F1nut Posts: 51,738
    edited April 2005
    IMO, it's best to use all the same wire.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited April 2005
    I have Cobalt Cable speaker cables on my LSIs but I am running Acoustic Zen jumpers. They sound awesome.
    Jumpers make a big difference on these compared to those brass doojobbies they come with.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Willow
    edited April 2005
    ok what about using two sets of the metal jumpers . Just wondering until I go out an buy a set of nanners or spades. I have DIY jumpers on my mains but my rears only have the metal ones
  • John K.
    John K. Posts: 822
    edited April 2005
    JF, you're needlessly concerning yourself over something that can't possibly make a difference. Speaker designers who've worked to create a quality sound don't then sabotage their own speakers with something that would degrade the sound. Over the distance of 2-3" involved any reasonably conductive piece of metal, such as the one already there, works fine and has no discernible effect.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2005
    That's not what members here have reported time after time. Many folks have found that replacing the stock jumpers has improved their system.
    Now as for worrying about whether jumpers are the same brand of wire... I'll take the 5th on that one...
    More later,
    Tour...
    Vox Copuli
  • Willow
    edited April 2005
    John, true to a point but it doesn't hurt. I have used DIY jumpers before and continue. Now that I think of it if they can use metal brakets then any speaker wire will do.
    I just hate trying to make them out of the Kimbers. like I said they are a pain to work with.
    F1nut Posts: 51,738
    edited April 2005
    As you've never tried it, how would you know???:rolleyes:
    BTW, how is that boombox rig of yours?
  • malikarshad
    malikarshad Posts: 527
    edited April 2005
    I use Cobalt Cable Jumpers on my rear speakers that is made of 10AWG and has a very good termination (spades/banana) . I had DIY 12AWG before that but the Cobalt jumpers are very well terminated. Though pricey at $24 after 40% discount but the build quality is very good.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • michael_w
    michael_w Posts: 2,813
    edited April 2005
    I'm going to try replacing my jumpers too. Just need to pick up a little extra wire and if I like the results I'll try and find some spades to make a nice clean set of jumpers.
  • michael_w
    edited April 2005
    Well I just put on a set of home depot special jumpers.... nothing fancy like spades or anything, just somethin cheap to try. The wire is 12 awg and about 30 cents a foot. Since it took about 20 mins inbetween music with stock jumpers to music with HD jumpers I couldn't really get a good a/b. I'm not going to say it improved drastically but I think the highs are a little more foward and it was definatly not a downgrade. I'd say it is an upgrade that is worth the money (a whopping 50 cents or something hehe) Heres a pic... and yes I know its dusty back there :p
  • Polkitup2
    Polkitup2 Posts: 1,641
    edited April 2005
    Here's what the Cobalt Jumpers look like.
