bi-wire or not
2283miker
I have a yamaha 2200 series tuner and polk 800i,s and 400i center and want to know if bi-wire would be worth doing.If so I have monster wire 12g,and how do I geta 2 ends into banana plug ?
Post edited by 2283miker on
NO!PolkFest 2012, who's going>?
I just got a set of monster bi wire cables, hooked them up to my rt2000p's and heard a noticeable improvement over using the bridge. It all depends on how much you are willing to spend to tweek.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Depending on who you ask, it may or may not make a difference. Get some cheap 12AWG speaker wire and experiment for yourself.
Regards,
PT -
bi-wiring is very subjective. I do it, because I CAN. Nice cool factor. Audible difference? Who knows.
2283, there're several discussions of biwiring on this board which you can find using the search function. It isn't significantly different electrically and factually can't make an audible difference. If you mean that you already have enough wire and want to try it anyway, but that the wire is too thick to fit easily, simply trim enough strands off the stripped ends so that they'll fit. Within reason, the gauge of the last 1/2" or so which is stripped makes no significant difference to the resistance of the entire length.
Another thing to play with is replacing the stock jumpers on your Polk's with heavy guage wire (12 or 14). This might give you as much improvement as a full bi-wire run.
As for fitting in all the wire at your amp end... many dual bananas accept banana plugs in their ****-end, so you just daisy chain in the second wire run.
Play with the options and decide for yourself.More later,
Tour...
Vox Copuli
