Rear surrounds again/7.1
Stocks_sd
Stocks_sd Posts: 28
edited May 2002 in Speakers
Could I get some opinons on using two cs245i's for rear surrounds? Thinking about using them or rt25i's. What do you think would be better.
Thanks,
Randy
Post edited by Stocks_sd on
  • juice21
    juice21 Posts: 1,866
    edited May 2002
    what are your side rears? if you are going with 2 rears, i would suggest either teh 25i's, or even 35i's...
  • Wesmo
    Wesmo Posts: 74
    edited May 2002
    well, I use the 245i as my center, and it's a great speaker (although I'd like to trade it for a 400i). I'd think it would be a little better than the 25i since it has two 5 1/2 inch woofers rather than one. You might also think about going with 35i's, which is what I have. I picked them up last week, and they've proven to be great surrounds with my 600i's.
    Wes
  • mantis
    mantis Posts: 17,394
    edited May 2002
    i DON'T GET IT, WHY DO YOU WANT TO USE THAT SPEAKER FOR SURROUNDS??WHERE ARE YOU GOING TO PLACE IT OR THEM???
    Dan
  • Stocks_sd
    Stocks_sd Posts: 28
    edited May 2002
    I might be making some changes with my speaker set up and I'm just going through my options at the moment.
    I have another thread titled "mantis" that I started right after this one. The two of these should have been one thread.
    Sorry,
    Randy
