XRt12 Tuner ????
Herdfan
Herdfan Posts: 13
edited April 2005 in Electronics
Is it possible to use both the Optical and Coax Digital outputs at the same time. I want to use the optical in the living room where the tuner will be and run the coax to the whole house distribution amplifier.
The manual doesn't say anything one way or the other.
Any input would be appreciated.
Thanks.
Mains - Rti10's
Center - CSi5
Sides - FXi5's
SVS PB2-ISD
AVR - Denon AVR 3806
HDTV - Hitachi 57S500
Denon DVD-2910
DirecTV HR10-250 (63 hours HD)
DirecTV R10 (207 hours)
Post edited by Herdfan on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited April 2005
    Can you hook the tuner up coaxially and optically to your Denon AVR? If so, switch the AVR from one input to the other with the tuner running. Since the XM tuner has no switching mechanism for output type, I'm inclined to believe everything is "hot" at all times. I use the optical and analog outputs simultaneously without issue.
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2005
    I don't see why not. I've used the coax and analog outs simultaneously on my XRt12.
