subwoofer hook up... woah
gaborow
gaborow Posts: 16
who knew this would be so difficult... i have the PSW 505 and harmon kardon avr 7300 w/ a subwoofer preout...
... i am not going to be hooking my speakers in line w/ the sub as per the "polk way"... so i need help with:
1. the "line in filtered" OR the "LFE unfiltered"... seems like i want to go w/ "LFE unfiltered" as will be using for HT a lot.
2. if i'm understanding it all correctly, if i'm using the LFE choice above, i will need to set my crossovers... any suggestions given my setup? RTi12's, CSi5, FXi5's....
3. when i'm listening to music it seems best to turn the surround off... if i do this with the above setup, should i keep my base management on? the hk avr7300 allows for this.
thx in advance... cheers.
HK AVR 7300
HK DVD 31
MP HTS 2500 MKII
RTi12's
CSi5
PSW505
FXi5's
Post edited by gaborow on
  • Willow
    Willow Posts: 11,308
    edited April 2005
    Don't sweat it we've all been there
    1 for HT use the LFE
    2 the rule of thumb is 80 for xover but you may want to lower that to 60 due to your 12's and set all speakers to small
    3 always keep bass management on you can use your sub for music as well. Yes turn off the surrounds, or if you like surround music , leave it on.
  • Frank Z
    Frank Z Posts: 5,860
    edited April 2005
    80hz is the THX standard. You might try leaving the fronts set to Large and see how it sounds to you. Subs and 2 channel don't always work well together. Try it both ways and see what works best for you.
  • Willow
    edited April 2005
    Frank you are right abou the sub an 2 channel I forgot he had 12's. I was thinking of my 4's.
  • gaborow
    gaborow Posts: 16
    edited April 2005
    thx for all your help...
    ... just to be clear, i should set all my crossovers at the same level?
    as it stands now i have the fronts sent to large, the center and rears set to small.
    HK AVR 7300
    HK DVD 31
    MP HTS 2500 MKII
    RTi12's
    CSi5
    PSW505
    FXi5's
  • Frank Z
    edited April 2005
    The easy way to do it is to keep everything the same but don't be afraid to experiment. Determine the frequency response of the speakers you have and start playing, that's half the fun.
  • gaborow
    gaborow Posts: 16
    edited April 2005
    i knew if i kept asking stoopid questions i would remember my question...
    .... i've looked at specs for my speakers and have no idea what they mean. what exactly am i looking for when determing crossover.... thx again and again.
    HK AVR 7300
    HK DVD 31
    MP HTS 2500 MKII
    RTi12's
    CSi5
    PSW505
    FXi5's
  • landry_p2000
    landry_p2000 Posts: 1,313
    edited April 2005
    You may be able to get away with setting that CSi5 to "large" for movies and for music you may be able to get away with leaving your sub on , but turn it down some. In my set-up the bass is a lot more powerful while listening to music than looking at a movie.
    Congrats on the RTi12s, and have fun with your new set-up. How many watts per channnel are you pushing out of that avr7300?
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • gaborow
    gaborow Posts: 16
    edited April 2005
    thanks again...
    the avr 7300 is pushing out a whopping 125 watts/channel w/ 2 channels... or 110 watts/channel all 7 channels driven.
    supposedly it's a honest conservative number from what i've read..... power amp is in my future though.
    HK AVR 7300
    HK DVD 31
    MP HTS 2500 MKII
    RTi12's
    CSi5
    PSW505
    FXi5's
  • landry_p2000
    edited April 2005
    That will push that CSi5 with ease. After my sub upgrade, that Csi5 will be next for me. That thing is a beast. You can feel the bass coming out of it during movies and listening to music in all channel stereo. Have fun, and don't let that damn upgrade bug bite you!;)
  • gaborow
    gaborow Posts: 16
    edited April 2005
    thanks again...
    HK AVR 7300
    HK DVD 31
    MP HTS 2500 MKII
    RTi12's
    CSi5
    PSW505
    FXi5's
  • Pinktulip7
    Pinktulip7 Posts: 249
    edited April 2005
    Stop crying dude...get SVS sub and try different setting for same movie see what setting sound better......
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • gaborow
    gaborow Posts: 16
    edited April 2005
    hmmm... i posted the same thing twice? anyway thanks again... been playing ard w/ stuff slowly getting there.
    HK AVR 7300
    HK DVD 31
    MP HTS 2500 MKII
    RTi12's
    CSi5
    PSW505
    FXi5's
