New Home
baboon
My new home came with a 5.1 home theater wiring. I'm not sure how everything will be like once done. From the looks of it they're using a bare thick wire for the subwoofer. I'm assuming that they will have a wall plate with a sufwoofer jack on it so I can connect my sub to the wall. If not, where can I get a wall plate that I can hook up a subwoofer too? Thanks!
Post edited by baboon on
That looks good.
You can probably find a wall plate at www.partsexpress.com.
They have quite a few options for stuff like this.Tschüss
Zach -
Will this work for the subwoofer? Thanks.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=261-340 -
