rti6 - lack of hi end?
Hello. I own rti A1's and A3's. I bought a pair of rti6's assuming they would sound similar. To my ears they don't. There is very little hi end from either rti6. Mainly bass and mid. Is this normal, or does it sound like there may be an issue? Is there a way to test the tweeters to see if they are working properly? Thanks.
    pitdogg2 Posts: 27,921
    Are the tweeters active? Can you isolate the sound by using your ear and a paper towel tube or something similar?
    Second, is there straps on the binding post cup if there's 4 binding posts back there?
  • high_voltage
    Thanks for the reply. The tweeters are working and the straps are connected. Could it be that these are very bass/mid heavy speakers? If I dial the bass way back the blend is much better. But they still seem to lack the clarity of the A3.
    gudnoyez Posts: 8,238
    I own RtiA9s A5s and A3s in a 7.2 System and no lack in the highs that series is geared for HT systems. I have heard the RTI series and thought they were a little to bright for me, as suggested do the paper towel trick those tweeters must be faulty.
    I'd remove the binding post cup and look at the resistors. You could post pictures, you're looking for obviously burnt or discoloration in the resistor.
    If the tweeter is still playing this would be my next move. If both speakers have the problem it would seem strange.
  • high_voltage
    thanks for all the suggestions. I will try some of these over the next few days
  • high_voltage
    Circling back. It seemed that the upper binding nuts were loose so the straps, while connected, were not fully tightened down. Not sure why, but tightening them increased the tweeter output by a little. I still believe these speakers are a bit low mid heavy. But at least now, I have a little more hi end to compensate.
