After Driving 12 Hours Yesterday....
The fruits of my labor. I don't quite know what to expect but need a neighbor to help me get them out of my trunk:
Awesome!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Kanta? N°2 or N°3?
Number 2. The seller also has a pair of Sopras he wants to sell soon. Really nice guy with some sweets Bryston, BAT, Luxman, and Oppo gear. I will say the Sopras powered by the giant Bryston amp, was a much more direct, tight sound than I am used to. Not necessarily bad, but different.
Nice. 12 hrs is worth it. I've been on a couple of those road trips.
You’ll love them. Kantas are great speakers2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Congrats on awesome speakers.
Focal speakers present a bit differently Than most other speakers. They tend to be extremely detailed and less forgiving with the distance off the back wall due to the front port. They also are extremely even response and don't produce an insane amount of bass. it's more natural and clean. You should use a high quality pair of subwoofers with them to really complete the experience.
The key to those speakers is setup . See those crazy carpet spikes? What is very nice is you can adjust them without having to lift the speaker. What you want to do is tilt them back some. Measure your ear sitting position height and what you want to do is get the tweeter just firing above your ear. A laser pointer helps but it doesn't have to be exact. Then you want to make sure they are level side to side.
I don't know if the plastic is still on the tips of the spikes, that is for hard wood but I don't like it either way. I Would put rubber cups underneath each spike, like Dining room chair round rubber cups. You can get them at Home Depot or a hardware store.
Here is another very cool thing about most Focal Speakers, they do not need a super powerful amp. You can Get away with a nice solid 100 watt Solid state amp and be very happy.
Suggestion
Drop the back to spikes so the speaker basically rests on the floor. Then jack up the front evenly for the tilt.
You also want about 3/4 width as the measurement in distance from the each speaker. So easy math is 10 feet from you to speaker and 7.5 feet in between the 2 speakers. Also keep them about 12 inches or more away from the back wall. If you can do only 3 to 6 inches off the back wall, you will just create a bit of a bass boost. That might be ok in your room , it may not.
Let me know if you need any pointers more to get them bad boys to sound wonderful. I did Focals for years and own a pair myself.I have had a few in my lifetime .Dan
I was able to move them in a well padded wheel barrow down a hill and into the basement without killing myself. Forget about lifting them up and down stairs unless you have a Schwartzenegger physique, which I no longer do. I plan on doing some serious listening this weekend.
Here is a pic:
Nice pickup!! Well worth the trip for sure. Many, many hours of enjoyment await!!
Are you going to wear them grilles on or grilles off?
Maybe you should add a pic with grilles off. -
Ill get some naked pics of them up soon. I will say moving them forward just 3 or 4 inches made a huge difference in the boominess. Also, these are a very tight, direct sound. Im am grateful for carpeted room at this point. Gobs of detail in acoustical guitar and Mick's voice fer sur.
Congratulations @kevhed72, "You have chosen wisely" lol. Yes, just inches to and from the wall can make a huge difference in the bomminess. I have mine 20" from back of speaker to the wall.
@mantis has some great advice on set up. I come close to having mine in a tri-lateral set up. Having the tweeter at least at ear level makes a tremendous difference, mine are on hockey pucks. And driving them with a tube amp???? Dude, nothing but love there. I got to hear a pair of Sopras on a tube amp and what a treat that was.
It was @stangman67 that inspired me to go Focal and I've been in 2ch bliss ever since.
And be sure to tell Clint, "Dying ain't much of a living boy"Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3 -
Quick update on these speakers after doing much Qobuz and SACD listening-these are probably end game speakers for me. The airiness between sounds and instruments on ambient and newer, electronic based music is breathtaking. The Stones music I have been listening to my whole life has never sounded better, and the bass is ultra tight. These fill the room with balanced sound effortlessly w no ear fatigue. I have really appreciated how some music is engineered with a certain overall tone or “theme” to the sound.
Questions for y’all on the tweeter height and the use of hockey pucks on the front spike….have you done this on carpet or a solid surface floor? -
Congrats on the new speakers! I'm not sure if you've already done this since taking the photos, but I strongly suggest removing the Polk L200s from the room and spreading out the Focals accordingly.
Even just having the L200s physically adjacent to the Focals like shown in the photo will negatively impact the performance of the Focals.
