replacement cone/coil kits for monitor 10, 6.5" mid/woofers?
13»
Answers
  • jayward
    jayward Posts: 35
    Nice! I'll have to buy some soon. Hoping to get to this over the winter. I admit, I'm still a bit intimidated by this project.
  • jayward
    jayward Posts: 35
    Thanks for the details. I sorta get it now. LOL. While I love sound, and playing around with this stuff, the specs aren't really my strong suit.
    xschop Posts: 5,931
    The wuhan MW coils have landed. These Spec'd out to 6.6 ohms each and fit the MW spud-jig perfectly, so no clearancing of the pole shaft its needed...
  • Gardenstater
    Gardenstater Posts: 4,991
    ^^Nice! I'm curious about the height of the coil and how it compares. Also O.D.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,931
    0.50" coil length
    1.060" coil OD
    1.40" total length
    These would also work in and clear a factory 6500.
    I really like the extra 4 holes for cooling too.
    xschop Posts: 5,931
    edited October 2022
    Another problem I've found in some drivers is that the QC at Polk was iffy on some when they positioned and glued the VC's as their coil to base-plate depths are all over the place.
    Every driver I've measured has a 0.23-0.25" thick baseplate so a 0.5" coil length should glue and set with 0.125" coil showing on the magnet side.
  • Gardenstater
    edited October 2022
    Mine only show around 0.050" and to make them show 0.125" you have to push on the cone which results in the spider being visibly dished concave. That was a. ssembly error.
    Not to mention the coils being cocked. I have to exert significant torque to make them perpendicular which also distorts the surround visibly in the process.
    I'm putting in the warranty claim right now :D
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    Maybe better to post this here:
    Just for the record, on my 1979 MW6500s I measure ID: slip fit to a 1.010 plug gage. OD: not round 1.057max, 1.054 min.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    This is sitting on one of the 2 alignment fixtures that I built. They will come in handy for voice coil replacements. I don't know how well these photos show it up but you can hopefully see that spider is noticeably dished. I'd have to do a video to show it but the front plate is very much not flat as well. I can spin the whole driver on the fixture and you can see that light shows at various changing locations between precisely machined brass standoffs and the front plate.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,931
    edited October 2022
    You'd be better off cutting the old coil out and replacing/re-setting with the newer one. Assuming your base-plate ID is @1.072 like the 6500's I've measured, you could possibly get away without clearancing the metal plate, but then you can still have more susp. sag over time and then you are back to same situation.
  • Gardenstater
    edited October 2022
    Yep. I just ordered the last 2 coils on eBay. Not replacing the voice coils isn't an option with these drivers. The nice thing about it is, these are superfluous drivers and will a be a lot of fun to use as test beds for modifications such as sound absorption underneath spider, shorting rings, disassembly friendly motor design, etc.. :)
    PS: I really want to get ahold of the test equipment to do proper A/B measurements too. Listening tests are subjective and need to be backed up with something to at least show that it isn't a case of "destroying" your speakers lol.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • jayward
    jayward Posts: 35
    So, it's been quite a while since I posted on here, and I wish I was posting they are all fixed and working, but between being intimidated by the project, and life getting in the way, that isn't the case. I am, however, back to pondering them, and trying to work on them again. This is how far I got before feeling stuck.
    The cone is out and in good shape for reuse, but not sure what to do about the spider. I was hoping to cut it out and reuse it, but can't seem to figure out a good way of going about it. I tried heating up the glue, but that did little to nothing. I tried getting in there with a razor, but it's pretty tight, and I don't see how I can get under the lip. The only other thing I can think to do, is cut them where they make the 90 degree bend and attach to the cage, and reconnecting them with a bead of glue around them in the 90 degree bend area. Is that what you guys do?
    As far as I can tell, I don't think the magnet shifted, although I could be wrong. If you go back in the post, you can see how torn and burnt up the voice coil was, so obviously going to need new 1's. So far, I have only dissected this 1 speaker, but I have to do all 4 of them for my set of 10b's. Again, any help is greatly appreciated. I've been waiting many years, to finally get to hear these, but really didn't want to do any harm to them, either.
  • jayward
    jayward Posts: 35
  • Gardenstater
    I don't know of anyone who has separated the spider to basket glue joint. If anybody has it would probably by xschop or lawdogg. I don't know for sure why you want to do it, but if you are certain you need to you could try a set of O Ring picks.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited March 2025
    If you want to see if the pole piece has shifted relative to the front plate, the way to do it would be with some flexible plastic shim stock. I found some houseplant plastic labels that were very flexible (Vigoro) that I got with some plants I bought from HD, that were about 0.007" thick. These happened to be about perfect for centering the voice coil on the pole piece in my case. You'd have to find what thickness you need for the gap between pole piece and front plate.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • jayward
    jayward Posts: 35
    Thanks man, from what I can tell, checking the way you described, the magnets are ok, But all the v.c.s are burnt up and pulled apart. I have since got them all to the progress of this 1 speaker. So far, so good, but 2 of the spiders did rip a little further out, due to more glue on them. So, 2 of them came apart easy and 2 of them I basically had to cut through them with my thumbnail, at the glue line, which left the center hole bigger and jagged. They can probably still be used, but the cone will have to go back in exactly as it came out, and I'll have to glue past where they ripped. Luckily, the above poster, link is still good for the v.c.'s but I'll have to contact the seller, and see if I can get 4 of them, since he only lists them in pairs, and is only showing 1 pair available. I need 4 of them.
  • lawdogg
    lawdogg Posts: 472
    edited March 2025
    I have never separated the spider to basket. The couple voice coils I've done, I used ~26mm coils and did them with the cone & spider in place. I think one was a MW6500 and one was a MW6502 iirc. One worked with plenty of pole clearance but was SUPER tight to the basket, one rubbed against the basket. I haven't found a voice coil that is completely drop-in.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • jayward
    jayward Posts: 35
    Mine are the MW6503's. 2 of them were already coming apart, and needed to be reglued. Plus, I figured it would be easier to start at the beginning for lining things up, etc. But it doesn't look like I'll be removing the spiders unless I want to replace them.
  • kevviek
    kevviek Posts: 17
    I’m having a go at rebuilding a 6502 that had a shifted magnet and destroyed voice coil.
    Shopping for parts I’ve found VC’s with 25.9mm or 25.5mm inner and 27.0 or 26.5mm outer. Both are too tight in one direction.
    So I was thinking of boring out the top plate but I don’t have any exotic tools to do that. Does it have to be precise, or good enough just to get clearance?
    Second question, closest spider I have found is 98mm x 25.8 x 6mm high. Does anyone know the right spec?
  • kevviek
    kevviek Posts: 17
    I tried this and was 95% successful but it didn’t matter because the inner edges were all split. The trick was to use Acetone, soak it for 10 minutes and then use an angled wood carving chisel to get under the edge, followed by a narrow flat chisel to push it around.
    I used the same approach to remove the rubber surround.
    F1nut Posts: 52,406
    kevviek wrote: »
    https://forum.polkaudio.com/discussion/201843/fs-a-boatload-of-polk-mw6502-drivers#latest
    xschop Posts: 5,931
    edited August 25
    I found that a Xi-bay JBL 4 ohm coil was a match (3.5ohm DCR)
    But it is best clearance the base plate ID 0.007" IIRC. I used a 1/2" Dremel drum sander in circular motion. I've repaired a few this way since I already had to cut out damaged coil anyway.
    Also can vouch for F1's 6502's being quality. Have spares from him myself.
  • kevviek
    kevviek Posts: 17
    xschop wrote: »
    The dremel is exactly what I had in mind, thanks for the advice.
    I’ve ordered a spider and will see how it lines up when it arrives.
    Have messaged F1 but I’m on the other side of the world…
    F1nut Posts: 52,406
    edited August 26
    You did?
    Edit: I was looking for a PM, but didn't see one. I just now saw your post in my for sale thread.
  • kevviek
    kevviek Posts: 17
    lawdogg wrote: »
    In the end I bored out the frame. Maybe too much…and the pole to VC gap was 2x the thickness of a photo negative.
    The woofers sound ok, but the SL2000’s are way bright. Will try increasing the series resistor but also wondering why people replaced the tweeter rather than adding a shallow notch filter at 13kHz?
  • lawdogg
    lawdogg Posts: 472
    My take is because there are other options that are easy to do, proven to work, and relatively cheap (like just replacing them with RD0194 tweeters) ... But for science, if you wanted to give the notch filter a shot and report back with results, I'd be very curious to hear what you think!
    <3 my 3.1TLs
