Polk Reserve R700 – Eight Pairs of Failed Tweeters (Vol. 2)
Ylbs
My experiments with speaker polarity
After repeated failures, I experimented with reversing the speaker cable polarity at the amplifier terminals.
I discovered that reversing the external polarity did not noticeably affect the bass performance.
However, the tweeters appeared to last longer.
## Crossover and my conclusion about tweeter protection
After repeated failures, I examined the R700 crossover board.
The midrange and tweeter sections have separate outputs on the crossover.
My conclusion is that the Pinnacle Ring Radiator tweeter receives more signal during loud playback than it can reliably withstand.
**I believe the tweeter needs greater attenuation or a more effective protection arrangement to match the output capability of the rest of the speaker.**
I am particularly interested in whether other owners have investigated the crossover's tweeter circuit, resistor values, filter slopes and protection.
## My current EQ settings
Today, my NAD C298 drives the R700 front speakers, while the Denon AVR-X6800H manages the surround system. My Marantz MM7025 is still in use, powering the rear speakers.
The other 11 speakers in my system have broadly smile-shaped EQ curves, with boosted bass and treble.
The R700 front speakers are different.
I have deliberately reduced their upper frequencies below the EQ zero line.
**With this configuration, the tweeters have survived so far.**
I also have Polk ES20 speakers positioned above the R700s and angled slightly downward, contributing to the overall front sound.
The current high-frequency performance is reasonably satisfactory to me.
However, I find it unacceptable that I have had to reduce the high-frequency output so significantly because I no longer trust the tweeters to survive louder listening.
I can provide photographs of the EQ settings and crossover if anyone is interested in examining them.
## Concerns about Polk center speakers
My current center speaker is a Polk ES30.
I have considered upgrading to a substantially more capable center speaker, such as the Polk Legend L400.
However, the L400 also uses Pinnacle Ring Radiator tweeter technology.
After experiencing eight pairs of failures with the R700, I am reluctant to purchase another expensive speaker using the same tweeter technology.
I have also encountered reports of tweeter failures involving Polk center speakers.
My concern is not whether a center speaker has the same power rating as a floorstanding speaker. It is whether its tweeter has sufficient durability and protection for its intended use.
This is one reason I have been considering replacing the entire front speaker system with JBL Studio 698 floorstanding speakers and a matching JBL Studio 665C center.
## Earlier Polk forum discussions
I have discovered that similar concerns were being discussed years ago.
**May 2022 – Dead tweeters on one month old R700's**
https://forum.polkaudio.com/discussion/comment/2684240
In this discussion, another R700 owner describes losing both tweeters during louder listening while the bass and midrange drivers continued working.
Polk supplied replacement tweeters.
The owner later reported that a Polk technician had mentioned a batch of defective tweeters.
Another participant also suggested checking the crossover for damaged resistors.
Related comment:
https://forum.polkaudio.com/discussion/comment/2684246
**June 2023 – Polk R700 Polarity & other issues**
https://forum.polkaudio.com/discussion/comment/2731332
This discussion was particularly interesting to me.
The author, HalfOhm, describes R700 speakers with disappointing bass balance and excessively prominent midrange and treble.
He also reports that changing polarity made the upper frequencies sound smoother.
Most importantly, he contacted Polk Audio about the internal polarity arrangement and reported that Polk confirmed the woofers were intentionally connected with opposite electrical polarity relative to the midrange and tweeter section because of the crossover design.
This is remarkably similar to the explanation my distributor eventually received from Polk.
These discussions make me question whether the issues I have experienced are really isolated incidents.
## What I would like to discuss
I would particularly like to hear from other R700 owners and technically experienced members about the following:
1. Have you experienced Pinnacle Ring Radiator tweeter failures during louder listening?
2. Do you believe the R700 tweeter receives excessive power relative to its capabilities?
3. Has anyone measured the crossover's tweeter circuit or investigated whether greater attenuation or protection would improve reliability?
4. Has Polk made any changes to the tweeter or crossover since the problems discussed in 2022?
5. Have Legend L400 owners experienced similar issues with the Pinnacle Ring Radiator tweeter?
6. Has anyone received a detailed technical explanation from Polk Audio about repeated tweeter failures?
I am not asking everyone to agree with me.
I have spent considerable time investigating these problems and have reached my own conclusion based on eight pairs of failed tweeters, different amplifiers, polarity experiments and crossover adjustments.
**My conclusion is that the Pinnacle Ring Radiator tweeter is not sufficiently robust for the output capability of the R700 during louder listening.**
I would welcome a serious technical discussion, including evidence that challenges my conclusion.
Thank you for reading.
Related comment:
These failures have all occurred while you are operating the speakers with external EQ? How do you know the tweeters aren't being driven harder through that EQ to compensate for the acoustic characteristics of your room? Have you run pinknoise sweeps of your room to see if there are some sort of high frequency suckouts that the EQ is having to compensate for?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Did Polk engineers design the tweeter? Or is it an off-the-shelf unit from Seas or Tymphany/Peerless?
Edit: Also do any of the diaphragms look distorted?Don't take experimental gene therapies from known eugenicists. -
I have some more basic questions.
- What volume level?
- How big is your room? Dimensions.
- Listening distance.
- Have you ever had satisfactory performance with this system and different speakers?
- Is your room highly damped?
- What kind of audio are you playing?
- Are the tweeters completely dying, or are you cooking them? Are you detecting a nasty fishy smell? (from the tweeters)
Your NAD looks pretty capable spec wise. Gut feeling here without the above info yet is that the volume is simply too high for how you're set up, and you're pushing the tweeters too much with the EQ to compensate for something else.
Polk speakers are not known for weak performance in the high frequency range. Garden's question is interesting. I've only ever had to work with bass suckout, but some high frequency loss somewhere seems possible, though I can't think of a situation where I've experienced it.
What kind of audio are you playing? -
Although I haven't had the experience of repeatedly blowing tweeters, I do have the experience of using Legend, including L800 and L400, and Reserve speakers for the last few years without any tweeter issues. The earlier LSiM ring radiator tweeters in a pair of LSiM707s did heat up noticeably to the touch on the bezel after being pushed at very loud volumes for more than 30 minutes with a Parasound A21 amp, but no failures. I haven't blown speaker drivers since the mid-1980s. The L400 is also not an easy to drive speaker so requires a high current amp powering it.
If I had to guess, the problems would stem not from the speaker design but the excessive use of equalization drawing too much amp power from the system as a whole to support exaggerated bass at very high volumes. Is the system properly calibrated to be level matched? The R700s are demanding speakers to drive because of the large for Polk woofers and the impedance curve dipping a bit low at some frequencies. They are also not all that efficient, but not really unusual in that respect.
Is there a good subwoofer or two in the system that could reduce the need for bass boost? -
I thought it was odd, when I compared the audioholics measurements with Polk specs, that Polk says minimum impedance of 3.6 ohms but I don't see it dipping below 5 ohms in audioholics measurements:
George / NJ
iFi nano iDSD DAC
iPurifier3
I have seen a few instances of these tweeters with issues before and chalked it up to over-clocking the volume dial....
https://www.audiosciencereview.com/forum/index.php?threads/blown-tweeters-polk-r700.46871/page-2Don't take experimental gene therapies from known eugenicists. -
Back of the Polk tweeter sure doesn't look like it is designed for good cooling, more for shielding which may be opposing design parameters:
What ScanSpeak flagship Ring Radiator Tweeter looks like:
George / NJ
iFi nano iDSD DAC
iPurifier3
I predict a future Wuhan mod to these when they go unsupported or thru the roof$Don't take experimental gene therapies from known eugenicists.
There is only one way to blow 8 tweeters and it has minimal to do with the speakers- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Some people are in the minority but may be doing destructive testing with EQ and desire for extreme sPL......
What a difference a tweeter makes (and $$'s)
George / NJ
iFi nano iDSD DAC
iPurifier3
Went through 8 pair of speakers. I could not comment or add to why all failed.
Are you willing to sell the other parts that do work? 8 pairs is a good amount of drivers. -
I think I would have taken a step back when the first ones failed. I got lost. Were you driving the R700 with the Denon AVR when the tweeters failed or the NAD?Stan
Main 2ch:
HT:
Other stuff:
He took a step back, but I'm afraid he has also taken a step back from the Polk Forum.
Only way to try to sort it out is to read both of his threads lol (Vol. 1 and Vol. 2). He used two different Denon multi channel receivers, then a Marantz and then settled on the NAD. Seems like all the previous failures were with Denon and Audyssey and the last failure was with the NAD.
https://forum.polkaudio.com/discussion/203040/polk-reserve-r700-eight-pairs-of-failed-tweeters-vol-1#latest
"Today, my NAD C298 drives the R700 front speakers, while the Denon AVR-X6800H manages the surround system. My Marantz MM7025 is still in use, powering the rear speakers.
I can provide photographs of the EQ settings and crossover if anyone is interested in examining them."George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »He took a step back, but I'm afraid he has also taken a step back from the Polk Forum.
One thing that stands out to me is the comment that the tweeters have survived since reducing the high-frequency output on the R700s. That's an interesting data point, and honestly probably one of the most important clues we've had so far.
Eight tweeter failures is well outside what we would normally expect to see, which is why I think it would be helpful to dig a little deeper into the system configuration rather than focusing solely on the tweeters themselves.
If he's willing and returns, I'd definitely be interested in seeing screenshots or photos of his EQ settings, Audyssey configuration, crossover settings, and any tone controls that are being applied. The reason I ask is that it's sometimes possible for multiple layers of processing to combine in ways that aren't immediately obvious. For example, room correction, Dynamic EQ, manual EQ adjustments, and tone controls can all interact with one another and potentially result in significantly more energy being sent to the upper frequencies than intended. It's something I learned in the pro audio realm during mixing sessions, a couple of EQs in a signal chain can drive some frequencies to distortion levels and other weird phenomenon.
I'd also be curious whether all eight failures occurred in the same speaker, the same channel, or if the failures were spread between both speakers. That information could help point us toward either a system-level issue or something more localized.
The NAD C298 is certainly capable of providing a substantial amount of power, and while clean power by itself generally isn't a problem, a combination of high listening levels and significant high-frequency boosting can place a lot of demand on a tweeter. I'm not suggesting that's necessarily what happened here, but it's one avenue worth exploring given that the failures appear to have stopped after the R700 treble levels were reduced.
I'd be interested in taking a look at the screenshots if they have a chance to post them. The more information we can gather about the signal chain and processing being applied to the R700s, the easier it will be to narrow down what's actually going on here.
