Is a B&K EX4420 a common ground amp?
TNTsTunes
Just wondering if I can use this with the blade/blade SDA SRS 2's I'm picking up tomorrow.
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life."
I just checked the B&K 200.2 that is replacing the 4420 in my main system tomorrow and it reads .2ohms on the 200ohm scale when reading from the l to R speaker grounds. It appears that it is a common ground amp, hopefully the 4420 is too. I'll check it once it's out of the system.
If not I'll use my Halo A23, I just like that B&K amps sound. I could use my B&K ST2140 too I believe."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
It is. I've used my 4420 with both 1.2's and 2B's without issue.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Hey, the search function worked today. How would this amp's sound signature compare to any other amps you've run on your SDA's?
Don't take experimental gene therapies from known eugenicists. -
@Nightfall ,hasn't been on in two years,Hoping he's ok.VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
IIRC he got tired of the bullying and bailed.
And the boots you lick will stomp you too. -
motorhead43026 wrote: »@Nightfall ,hasn't been on in two years,Hoping he's ok.
He should come back. Now most of the bullys have all gone. -
Well if he answers, cool. If not, that's cool too. We should all respect everyone's opinions and answers and make our own based on observance.Don't take experimental gene therapies from known eugenicists.
I don't know but it is a great amp
It's unknown whether Unknown knew anything.Don't take experimental gene therapies from known eugenicists.
Only unknown knows .VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
That's a known fact Jack.Don't take experimental gene therapies from known eugenicists.
