Is a B&K EX4420 a common ground amp?
TNTsTunes
Just wondering if I can use this with the blade/blade SDA SRS 2's I'm picking up tomorrow.
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life."
I just checked the B&K 200.2 that is replacing the 4420 in my main system tomorrow and it reads .2ohms on the 200ohm scale when reading from the l to R speaker grounds. It appears that it is a common ground amp, hopefully the 4420 is too. I'll check it once it's out of the system.
If not I'll use my Halo A23, I just like that B&K amps sound. I could use my B&K ST2140 too I believe."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
It is. I've used my 4420 with both 1.2's and 2B's without issue.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Hey, the search function worked today. How would this amp's sound signature compare to any other amps you've run on your SDA's?
