Pre-amps
Grabber70Mach
in Electronics
So my setup right now is Polk Monitor 5's with an Adcom GFA-5400 with a GTP-602 pre-amp and a Wiim Pro plus. I also have a pair of Polk SRS+ speakers that may be hooked up to this at a later date. Thought about picking up a Emotiva BasX PT-100 that is local to me. I have a Adcom GTP-500II that won't power up that I might do a partial trade with for the Emotiva. Or if it's a better per-amp see if he wants to accept the GTP-602 in trade for the Emotiva. Thoughts?
Adcom amp? Stick with that Adcom pre. That would be my thought anyhow. Have fun!
Are you not happy with that GTP-602? Most of those Adcom pre amp with tuners are all over ebay. I paired a Vincent SA-T1 with a refurbished GFA 555II and it was a good match. I would look for something else besides that Emotiva if you are looking to replace your current Pre Amp. How much are you willing to invest?Home Theater
Can't really say that I'm unhappy with the 602. Just thought the optional type of inputs might be a better choice for my Wiim, also liked the subwoofer output for the option of adding a sub in the future. To be honest I'm thrifty, just retired recently so not much to spend on this right now.
My experience with the GTP is that it had a significant noise floor. Maybe look at an Adcom pre without the built in tuner.Enjoying the journey while never attaining the destination.
