HVAC question
gudnoyez
Central AC Tempstar 25 years old motor went out figured why replace the motor at that age as I was told if the compressor went out it would not be repairable.
To make a long story short I decided to replace it with all the BS of avalibllity of items, and needing one fast was able to find dealers with stock. The choice of brands available are Trane or York, which one should I choose?
Which one has the best warranty?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Looks like they have 10 year warranties one year Labor, Trane's are a bit pricer they both get decent reviews Trane seems to be the favorites. I'm not going top of the line on models offered of both brands plan on moving in the next few years.Home Theater
If you don't plan on hanging around, go with whatever one has a transferable warranty to the next owner, as a selling point- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Visit the cost of motor versus cost of new unit. Motors, while expensive, are nowhere near the cost of a new unit. Everything is a gamble and things ain't built like they used to be.
There are other factors as well but weigh them all before pulling the trigger. My 2¢, no one else's....
By "moror" I assume you mean the condenser fan (aka "bellyband") motor
Not that expensive, easy DIY, and available at Lowes, Home Depot, or Grainger.
Check with your local electric company too for energy rebates/discounts on ne AC units
They'll give you a list of approved/certified installers who should be able to tell you about rebates .
Sal Palooza -
Fan motor went out, other than that it's hard to find parts for it, prior to that motor fan going out we noticed it wasn't cooling as well as it used to possibly needing a freon recharge and R22 is no longer available. Plus besides its age the seer value is low on an old unit like that.
That's why we want to replace it. We bought the house next door to us last year for the Daughter and grand kids to live in and it has a fairly newer York system in it. Availability on most anything is hit and miss any more and it's a take what's available kind of world we live in. I have read a lot of good things about Tranes quality they and American Standard seem to be the preferred ones. The York is also rated pretty well and less expensive but I'm leaning towards the Trane.Home Theater
It's hot humid and miserable. I went to menards and bought a portable 10,000 unit that you can move it around from room to room. The Wifes staying at the kids house so I'm setting it up in the 2 channel room cool it down and crank the tunes the house to myself what could be better.Home Theater
Ended up getting a Trane, it's been put to the test the past few days hot humid , today it was 98 with 112 heat index. Runs quiet cant even hear it unless your standing next to it. These Midwest summers can be unbearable.Home Theater
I'm aware this is an old thread...
But!
If someone has a similar issue, especially on a newer unit, I guess it's more common for the condensers capacitor to be the issue than the actual motor.
My York unit had the fan stop spinning in the middle of a heatwave this year. Thankfully my brothers business partner is an HVAC specialist. My system is only 5-6 years old, so absolutely worth repairing.
They started with the capacitor, as it's a cheap fix and usually the issue. But in my instance, it was the actual fan motor that went bad. I guess it's common practice to just replace the capacitor while they are there anyway, and there is the possibility that if the capacitor was going bad, it could've damaged my motor.
Fresh capacitor and fan motor, my system is back to running 100%. -
Ha thst Trane is doing its job its 95 with a nasty heat index here in the midwest and its keeping it cool. What you guys upgrade your AC's also😆Home Theater
Our Trane is doing great too.
8 years old or more.
It senses humidity too and cools below a set temp to get rid of it.
My wife hates cold!
I like it.
Good advice on checking the capacitor first. It can prevent unnecessary motor replacements.
