Speakers and amps an impedance
I'm test driving an integrated amp. I know the amp can be run at either 8 ohms or 4 ohms. I've been enjoying it at the default 8 ohm configuration. I think I'm finally hearing what others have been saying about the Polk L600s in that a sub isn't really needed and the clarity/mids are great.
But as usual I wonder what changes I could expect if I change it to the 4 ohm taps to match the nominal impedance of the L600. I hesitate to change this myself as the unit is a loaner and it;s not exactly EZ PZ to do.
Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
    billbillw Posts: 8,346
    edited October 16
    I guess that depends on the amp. What are we dealing with here? Class A/B, Class D, Tube amp? I know with the Class A/B amps that use a switch, things generally sound better if you leave it a 8 ohm and just use common sense with the volume knob. The switch usually enables some current limiting.
    Class D amps often prefer lower impedence and make really stable power at 4ohms.
    I don't have any tube amp experience, so someone else will have to chime in if that is what you are looking at.
    How is the change made on this particular amp?
    heiney9 Posts: 25,714
    You don't mention, but sounds like you are running a tube integrated?
    Tubes are a different animal than solid state. They are only as good as the output transformers.
    It also sounds like it's doing a pretty good job if you are hearing the extended bass you didn't with what you were running before. I can say as an owner of L600's in a medium sized room, I don't need subs for music.
    Trust me..............I don't
    What amp, what do the connections look like that it's not easy to change taps? You won't hurt anything just make sure the unit has been powered off for more than a few minutes.
  • muncybob
    muncybob Posts: 3,341
    Correct on the tubes call. Trying out the Rogue Audio Cronus Magnum III....not the dark edition.
    The wires are so small and in a bit of a cramped area and with the tremors I get in my hands it would not be easy for me.
    edited October 16
    billbillw wrote: »
    I does ALL depend on the amp and he hasn't told us yet. Current limiting by a switch (on SS) is not a particularity good amp.
    The biggest knock on class D was always they couldn't handle less than 8 ohms.....that has changed in the past few years as designs have matured.
    muncybob wrote: »
    That's a well built beefy amp. Usually the 4 and 8 ohm taps are speaker terminals and swap speaker cables. I didn't realize there was a small internal switch.
    edited October 16
    heiney9 wrote: »
    It's been more than a few years. My old Wyred 4 Sound ST500 made 250wpc into 8ohms and 550wpc into 4ohms without a sweat. That was a design from ~2008 or so.
    Back to Bob's issue. I was reading a review of the Cronus Magnum III at Enjoy the Music, and it does sound like it is bit of work to change from 8ohm to 4ohm output. Its not a switch, but you have to move wires around inside the chassis.
    "The amplifier is factory set to match 8 Ohm speakers. But you can adjust the speaker load resistance to either 4 or 8 Ohm's depending upon your speakers. But this involves a bit of work. You need to:
    1. With a Phillips screwdriver remove the 14 screws holding the top cover. At this time you would have removed the four KT120 output tubes. Insure the amplifier has been turned off for about 30 minutes and the amplifier power cord is connected a ground.
    2. With a 0.5" wrench remove the outermost nut from the red positive binding post. Leave the black wire with heat shrink on the post.
    3. Remove the 8 Ohm tap (Green wire marked 8) from the binding post. Careful to leave the black wire with heat shrink on the post.
    4. Remove the polyurethane tubing from the yellow 4 Ohm wire and lug.
    5. Place the polyurethane tubing on the 8 Ohm wire and lug.
    6. Place the 4 Ohm wire onto the binding post, and then replace the outer nut. "
    That sounds like a patience tester, but it would probably sound better if configured correctly.
    That is involved. Must be a reason they don't just use the speaker taps like many other designs. Probably for better sound and performance.
    I could be mis- remembering class D amps of the past. I was never interested in them because I didn't care for the sound profile. Watts has never been a good indicator of sound/performance unless your only goal is high SPL. I'm speaking in general and not knocking any one's gear just because it's high wattage.
    The past 20 years I haven't had more than 30 wpc in a SS amp. My current amp is 25 wpc and I still haven't reached its limits.
    edited October 16
    I've had a few speakers that really needed the watts and current in my large room. I actually need more for the PSB Stratus Gold in my living room now. I'm being patient with plans to get some of the newer Class D monos that can push 500 or so watts into 4.
    The NAD I'm using has an auto current limiting circuit, so it doesn't really put out any more watts or current into 4ohms than it does into 8ohms and it is something like 150w into either load.
  • muncybob
    I guess if I decide to purchase the Cronus III I'll just have them change to 4 ohm for me.
    Spent some time with the amp last night and amongst other things I realized it is quick to point out to me if I have a poor recording. The Mrs wanted to hear the only Whiskey Meyers cd we have. This followed Paul Simon's Graceland. Wow, I wanted to change the WM cd almost Immediately.
    Looks like if we buy this we'll be parting ways with a number or pieces in the rig.
    SCompRacer Posts: 9,404
    edited October 17
    Back in the McAlister days we talked about transformer design. He wound his own output transformers instead of providing specs and outsourcing, which I thought was unusual. After winding, they need vacuum processing/potting so not easy.
    Multi-tap output transformers use a single secondary winding with ohm connection points tapped in at specific turns. Unused portions of the windings can slightly compromise high-frequency response or leakage inductance.
    Series and parallel winding transformers consist of multiple internal windings. They are either connected in series or parallel to arrive at the desired 4 or 8 ohms. They use all of the wire/windings all of the time. I read it would cause issues adding extra wiring/rotary switches to change configuration, and you know someone would turn them while in use which might make a speaker pop, thus the manual wiring.
    Like all things in audio, opponents and proponents for both. The quality of the windings matters too. I'm sure doc hardy would know more about this than I recall.
  • muncybob
    So we are getting our 1st new piece of audio gear in well over 30 years...taking the plunge on the Cronus Dark edition. Are PS Vane tubes held in high regard, never tried them. Was told I could expect well over 1000 hours?
    I read that being able to bias all the output tubes makes not getting matched pairs so significant?
  • skipshot12
    skipshot12 Posts: 2,167
    I know nothing about tube amps but, looking up that amp it looks beefy with plenty of current.
  • muncybob
    They don't have the spec on amps but while I was testing it out I preferred running it in linear mode with the amp set on 8 ohm taps and I would have sworn it was putting out a lot more than 50 wpc.
    edited October 23
    Tube amps always sound more powerful than their specs would suggest. Also, remember that on paper, 50wpc is enough to drive those to over 100dB.
  • muncybob
    Yep, couldn't turn the volume up over 10 -11 o'clock and still enjoy the music in a fairly large room.
    Old Stock tubes have always sounded better to me by many magnitudes. I understand completely that some don't want to go down that hole for various reasons. But they and you will miss out on what a great tube piece like yours is capable of.
    I have found power tubes like current stock Genelax Gold Lions and Tung Sol sound really, really good. It's the pre-amp tubes that can really make a nice piece of gear shine. Old stock FTW, by a lot
    If one doesn't want to go down the Old Stock rabbit hole. I think the best sounding current tubes overall are Genelax Gold Lion pre and power tubes. These are Russian made, but to the specs (as close as can be done) of the original Genelax tubes. They aren't inexpensive but worth it, IMO
    The reason new gear doesn't come with Old Stock tubes 1) very hard to reliably source in quantity (in fact almost impossible). 2) cost....if they could find enough to reliably source the added cost would be enormous.
