Trim rings on the Legends
Hello. First post and a question. How do I remove the trim rings around the drivers and tweeters? I want to tighten them just a bit, as I have done on some of my other speakers, many of which loosen a bit in the first few months of use. Thank you for the help.
    xschop Posts: 5,837
    edited October 15
    @VR3 may know.
    Welcome aboard.
  • muncybob
    muncybob Posts: 3,326
    Good timing on this question as I would also like to check my drivers as it's been around 3 years since I bought them.
    Yep, my name really is Bob.
  • Gardenstater
    Gardenstater Posts: 4,944
    edited October 16
    Tweeters:
    https://support.polkaudio.com/app/answers/detail/a_id/7215/
    Midwoofer trim rings attaches "like a grill with pegs". Looks like maybe quan. 6 pegs? If you want to be careful I'd apply painter's tape to the baffle to prevent marring it with any prying tools and try first off to use a thin plastic spatula or putty knife or the like. @VR3
    https://forum.polkaudio.com/discussion/194617/polk-l200/p1
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 29,751
    Sorry I missed the tag but yes they pull off like a grille
    xschop Posts: 5,837
    Tweeters:
    Nice phake plug.
  • Gardenstater
    xschop wrote: »
    Tweeters:
    Nice phake plug.
    And not to be overly critical (oh ok maybe a little) but look how they weakened (made less stiff) the baffle lip by making 6 large cutouts in it for those beauty rings. I mean they may help with diffraction but is the cost too high? Still only 4 screws coupling to the baffle and I'm betting the steel is thinner than our vintage baskets.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited 6:44AM
    The ends of the beauty ring pegs are ball shaped like a grille peg. You can see how this one was damaged in the removal process by whatever tool was used to pry them out. This one is from an R500. I don't know if there was design variation in the legend models.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
