Roon Bridge with Windows 11 - scaled down Win11 with Tiny11
ALL212
ALL212 Posts: 1,686
Kinda tired of all the junk MS installs that isn't needed to run Roon Bridge. So I did a bit of meta research and have installed Win11 with Tiny11.
It works. Not sure what else is removed but no more OneDrive, no more browser (install your own), no more teams, no more... other stuff.
You'll need to download the files, run some powershell, use Rufus, rebuild from scratch your Roon Bridge. So it's not a snap, crackle, pop setup but it runs cleaner and you can probably use much lesser devices and get good results.
Still in testing but I have two devices rebuilt now - seems to be fine...so far.
Aaron
Enabler Extraordinaire
