MW6510 impedance fluctuation
Long time since I've posted, lots of things going on.
I just picked up a pair of SRS 2.3TL that need a little help. 3 tweeters were blown and will be replacing them with 098's.
All the midwoofers are free and move smoothly. I have measured the resistance on 5 of them so far and with 4 of them the impedance jumps from 5.9 to 8.4 ohms. 1 has measured a steady 8.1 ohms.
I have already rebuilt the crossovers and that has helped with clarity. I stole the 098 tweeters from my 3.1TL and used the remaining good measuring SL3000. Sound is not right yet and I'm guessing the 6510's that measured squirrely are part of the problem.
Any thoughts?
Stubby
Polk SDA SRS 2A
Aragon 8008X3
Aragon Soundstage
Multiple Digital Sources
    xschop Posts: 5,875
    Hmmm... I call meter anomoly.
    F1nut Posts: 52,406
    They should measure 6.5 ohms.
  • stubby2
    stubby2 Posts: 49
    I considered the volt meter might be flakey, it's possible but I did get steady readings from the tweeters and at the speaker terminal binding posts. (3.5 ohms)
    Looks like I should start looking for some new(er) 6510's. None of them registered 6.5 ohms consistently.
    Also, when I did the left/right balance test for proper SDA function, the dimensional drivers were barely audible. Barely.
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
    F1nut Posts: 52,406
    edited August 23
    The dimensional drivers play at a reduced volume compared to the stereo drivers.
    You did disconnect the drivers before testing, right?
  • stubby2
    stubby2 Posts: 49
    F1nut wrote: ยป
    I was pretty sure that was the case with the dimensional drivers, these seem to be particularly low output. Had to put my ear just a few inches away from them to hear anything.
    I did disconnect them. ๐Ÿ™‚
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
  • Gardenstater
    Gardenstater Posts: 4,960
    edited August 23
    First off I would try another meter if you have one, and/or put fresh batteries in this one because DC resistance (not impedance ๐Ÿ™‚) should 6.57 Ohms. Are the driver's voice coils scuffing or rubbing at all when you manually move the cones? I think those MW6510s have a really high compliance and may be likely to over extend or have the suspensions wear out. Even if no rubbing detected, I'd also try measuring the resistance with the cone in different positions to see if that changes the measurement. 3rd I'd check the tinsel lead connections at the terminals. If that doesn't yield the answer, I'd cut the dust caps off and look at the connections there. Heck I'd be installing Rob's phase plugs anyways on the good ones so that's just the first step ๐Ÿคฃ
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 52,406
    F1nut wrote: ยป
    Possibilities, wiring/connection/polarity issues, crossover components in the wrong place, bad drivers. Are the red binding posts on the left or right?
    Post some pics of the crossovers, etc.
  • stubby2
    stubby2 Posts: 49
    Well I feel a little stupid. Nothing new, but I always hoped I would get better.
    ALWAYS double check your work!!
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
    F1nut Posts: 52,406
    What did you find?
  • stubby2
    stubby2 Posts: 49
    On the right channel I managed to swap 16 uF cap with 18uF cap.
    And don't give any hassle with the Solens. ๐Ÿ˜‰
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
  • stubby2
    stubby2 Posts: 49
    Lol, post 45 was supposed to have pics.
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
    F1nut Posts: 52,406
    edited August 23
    That'll do it. Glad you found the issue. Still doesn't explain the driver readings though.
  • stubby2
    stubby2 Posts: 49
    Thanks to everyone who chimed in!
    And that is true about the driver readings. Burn one bridge at a time !
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
  • stubby2
    stubby2 Posts: 49
    Made the appropriate change with the caps and it did make an improvement.
    Just for fun I replaced the factory jumpers at the cable terminals and that helped tremendously. Just some cheap monster wire that was laying around.
    I also finally ordered new tweeters to replace the 4 SL3000s that are remaining.
    And then, just received a pair of Galion Discovery mono blocks. Still need some hours on them, but my goodness. These things bring dynamics and punch like I have never experienced with big SDA's. Only 80 WPC at 8 ohms and 120 at 4ohms. Would never have believed it.
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
  • stubby2
    stubby2 Posts: 49
    120 @ 4 ohms, shoot you're not even waking them up ๐Ÿ˜œ
    I did a full recap, Path resistors, sonicaps and all new inductors and C-coil. All inductors calibrated as close as possible. My set sits at 2.6 ohms, my Aragon 8008bb amp doesn't break a sweat and puts out about 700-800 wpc at those ohms.
    I hear ya. On paper it shouldn't work out but the way they sound is incredible.
    I have used the Aragon 8008x3 and love it but these Galions are something else.
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
  • Unknown
    edited September 2
