Hi new to the group. Please see my question in the box below. Thank you in advance your opinions are
I have two entry level Polk systems. Each is connected to a Denon 1612 AVR. The first system is a guest bedroom full 5.1 home theatre consisting of XT15 L/R, T30 CC, SW100/10 Sub & Bose 100 surrounds. The system sounds fine for what it is. My plan is to upgrade the T30 in the bedroom at some point to an XT 30.
The other system is in my home office and is just a2 channel stereo using T15 speakers.
My question is this, neither are my main system nor are they critical listening systems. The XT15s & T30 have a slight timbre mismatch. If I swapped the T115s in the office with the XT 15's would it make any difference in the guestroom system. I believe the XT15s in the office would make a difference there.
Answers
My recommendation would be to swap them and see what you think?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Only one way to know and welcome to Club Polk.
Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
Welcome @GOODD1!
A lot of great people here with lots of experience! And will always help with spending for new gear 😂 -
Ultimate support group in reverse as we enable the behavior
One of us one of us- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Welcome @GOODD1
I wish my guest were as critical of my guest BR rigs as your's are ... Than again maybe not lol.2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: Magnepan LRS w/Magna Riser stands
